Random Pics o' The Day
Started by SHOdded, September 07, 2014, 09:00:38 AM
southtxSHO
Quote from: SHOnUup on December 27, 2014, 10:36:32 PM
Quote from: southtxSHO on December 27, 2014, 02:14:58 PM
Brake boosting the same as always 2k RPM . Didn't have time to lower tire pressure and remove spare and Jack . But it seemed like it was hooking good , didn't hear tires spin .
To expect the better results you're going to have to test the limits. Drop tire psi, I'd say 27 front and 28 rear (not to drastic but will help) and up the launch rpm until it's to much.
Be sure to remove spare, jack, and have low gas. Those 3 not taken care of could be at least a tenth in weight.
Rich
Thanks for tips Rich 👍
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
Quote from: southtxSHO on December 27, 2014, 10:38:09 PM
Rich
No problem.
Good luck also, keep us posted on the next time out.
Rich
southtxSHO
Quote from: SHOnUup on December 27, 2014, 10:41:57 PM
Rich
No problem.
Rich
I sure will , our car organization is planning on a track rental day next month . Should give me time to get the noisemaker eliminator pipe and install the meth kit .
2011 SHO non PP
LMS 4 +tune
LMS Cai
And if there's any way you can get hold of a good 93, bump the car up to a 4X tune :)
Anyone have a clear pic of the rear valve cover,preferably the crankcase vent oil seperator on a 13 SHO,thanks Z.
91hybrid
Does this help?
2014 SHO -PP, Unleashed Tuned, 3bar, Devils Own 100% meth, PPE catted down pipes, 3rd cat delete, Magnaflow 2.5" exhaust, 170 deg, NGK 7's plugs, hot pipes - White Platinum 401a
418 whp - 513 wlb/ft
non meth 13.11@103.6 (knock limited)
Meth pass 11.991@114.28
Quote from: 91hybrid on December 28, 2014, 01:46:39 PM
Does this help?
If its no trouble,you have one on the other side of the oil seperator,thanks.
91hybrid
Try this...
Quote from: 91hybrid on December 28, 2014, 02:45:07 PM
Try this...
Thanks so much,like the meth connection there,thats my next project!!
Glad to hear she's all fixed up ZSHO.
Rich
Glad to hear that you found it... Turbo leaks can be tough to locate!
BTW, This is why I went with hard hotpipes.
Thanks guys,the dealer replaced the rear valve cover and the oil seperator under warranty,she's really running strong know,cant wait till spring to hit the track with the meth project next on the agenda,also they found alot of oil in the crankcase.
Keep us updated on how it all pans out, Z!  Any noticeable difference in exhaust growl ;) ?
91hybrid
Quote from: ZSHO on December 29, 2014, 10:24:12 AM
Kinda confused, but isn't there supposed to be a lot of oil in the crankcase?😜
Quote from: SHOdded on December 29, 2014, 11:17:18 AM
The car seems noticeably louder,with a deeper growl as you mentioned,also have to really hold two hands on the wheel now,cause prior to this,there was lack of power which was fustrating.
