Was just looking at the rules and tips from local dragway. It states that if you are on street tires, "DO NOT drive through the water box! Your treaded tires will pick up water in the treads, and when you do burnout, it will sling water all over inside the wheel well. You will then track water all the way to the tree, and water will be dripping down onto your tires, making them very slick! If you do this, you make the track dangerous for everyone, and you may be asked to leave if you do it again. The water is for slicks, not treaded tires. Etc...."
Lapeer Dragway via the "readme for beginners" tab
