AIRAID responded to my Email After viewing the photos the first thing I did notice is the weather strip is actually installed backwards, the curve of the blade should go away from the air box not towards it. This may or may not be causing the issue however we can get you a replacement. Where are you located? Regarding the taller type strip my guess is you may have been reading some of the recent posts on the forums about customers modifying the Airaid system for track use. We can provide you with the taller strip however if you elect to go this route please use caution as the taller blade type weather strip could potentially create an issue with the hood closing properly and/or premature wear to or actually cutting thru the under hood pad due to the added height.
Mark Fowler
Lead - CSR
AIRAID Filter Company
2688 E Rose Garden Lane
Phoenix, AZ. 85050
P. 602-652-9727
F. 602-652-9827
