Drags tonight
Started by Mikesb, August 16, 2014, 11:57:15 AM
Mikesb
It's been a while for me here but still the Eco enthusiast.  Tonight will be the 1st 1/4 I've ran w/this car. Looking for recommendations on launching. All trac-control off and leave in sport mode and let the car shift itself?
2013 SHO PP BLACK 7k mi - 12.9 @107  LMS 91 v8 METH TUNE - ALKY CONTROLS METH - 3-BAR - AIRAID - PPE DP'S w/cats - CORSA CB - PLUGS - T-STAT - UPGRADE AUDIO
PORTLAND OREGON
ShoBoat
Leave it in D, traction control in sport mode and launch at about 2k. That's been my fastest times. You can play with the launch rpm a little, your individual car will differ slightly. When I got my 1.8 60 foot I launched at 2200.
2012 Pearl White CTS-V Stock
Drop air pressure in tires to 30 or slightly less. Remove all weight and stage really shallow. Good luck.
Remember to check tire pressure after a few runs as it will increase.
Josephm
Take out the spare tire, floor mats, and stuff in glove compartments if you are looking to get your best run. I remove the Engine cover as well, I have a theory that it holds the heats and provides for less cooling.
12' Flex EB
Unleashed X4
3rd Cat delete
ecoboostsho
I will be going next week myself...I assume you just drive around the water and burnouts are obviously off the table...?
Quote from: ecoboostsho on August 16, 2014, 12:42:33 PM
Correct.
ecoboostsho
Thanks...first AWD vehicle at the track...
Quote from: ecoboostsho on August 16, 2014, 05:14:45 PM
I know most folks launch 2k ish, but my best time was had with a 1500 rpm launch.
Hopefully you have Torque or Dash Command as our stock tach is useless on the fine end...
ecoboostsho
Yep...definitely equipped. Thanks for the tips!
If your picking up gravel or dirt on the way to line up a good little burn out won't hurt to clean the tires...avoid the water for sure
Mikesb
10.8
Not - they unexpectedly canceled at PIR. Woodburn has drags tomorrow and it's ford only day. Might go there or wait till next fri, sat night at PIR
PORTLAND OREGON
Josephm
#12
There a pretty cool event in Bremerton next weekend. Its on facebook NW Street car challenge...Mike you should run that car there, I am sure you would shock allot of people
http://www.kstuned.com/pages/northwest-nights-street-car-challenge
12' Flex EB
Unleashed X4
3rd Cat delete
