May 30, 2023, 11:45:26 AM
Author Topic:  BSFC for 3.5 EB  (Read 5746 times)
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 707
  • -Received: 1158
  • The Tenth Man
  • Liked:
  • Likes Given: 2
BSFC for 3.5 EB
« on: July 16, 2014, 11:39:41 PM »
So, I'm assuming you have dyno'd the 3.5 EB a time or two.
Can you tell me the brake specific fuel consumption number (BSFC) overall and at WOT?
I need this number to fine tune the dyno on Dash Command and I'm having a hard time finding it.
Offline Leading Edge Tuning
  • Jr. Member
  • Houston, TX
  • Thank You
  • -Given: 1
  • -Received: 0
  • Leading Edge Tuning
  • Liked:
  • Likes Given: 0
Re: BSFC for 3.5 EB
« Reply #1 on: July 17, 2014, 09:20:03 AM »
I have, but I don't know the answer to that, there is a different calculation used for tuning...If I had to guess, I would say overall would be .6 and WOT would be around .7...those figures would be higher if you are mixing corn...
Leading Edge Tuning
www.leadingedgetuning.com
sales@leadingedgetuning.com
* Recent Topics
Re: 1st time owner
by SHOdded | May 15, 2023, 04:39:13 PM
nice ride, nice wheels. welcome and congrats!...
Re: New Member from Cincy
by PDSHO | May 14, 2023, 09:34:42 PM
Greetings from Nebraska.Also Go Bengals!Greg...
Re: White Smoke, Shuddering on brand new turbos
by jordanc67 | May 09, 2023, 12:54:12 PM
idk if this is the case here but apparently white smoke can also be ca...
Re: New 3 bar MAP - Now engine surges and multiple dash error lights
by SHOdded | May 08, 2023, 06:30:31 PM
if you replaced the 2 bar map with a 3 bar and did not tune for it, th...
Re: 3rd cat & resonator delete feedback
by kryptto | May 08, 2023, 05:27:41 PM
Do you mind sharing the part number ofDescriptions.  Or should I ...
Re: BOV - truths - education
by kryptto | May 08, 2023, 05:12:46 PM
Hey all, just an update and I am sure it won't be a surprise.&nbs...
Ford Taurus Sho makes grinding noise
by Mnelson | May 08, 2023, 11:11:49 AM
My ford Taurus sho usually makes a grinding noise when the tires spin....
Re: RockAuto.com Discount Code - Expires October 5, 2022
by SHOdded | May 06, 2023, 04:25:00 AM
idk if rockauto is still monitoring this site. but in the meantime, go...
Re: Piggy back vs flash tune. Which is best?
by Macgyver | May 03, 2023, 02:00:29 PM
Non E 91 is a good choice.5000 ft is tough on turbo output but the tun...
Re: UPR catch can kit
by Macgyver | May 03, 2023, 01:58:56 PM
Ford OEM rotors are bad. Same issues with the Edge ST. PP rotors are b...
