Power Transfer Unit (PTU) Equipped Vehicles*** READ THIS
Started by MDesign Performance, July 07, 2014, 10:34:10 AM
ShoBoat
Quote from: jmr061 on July 08, 2014, 10:11:18 AM
To me not having a temp sensor is odd. How would it know it's overheating. Let me look into the 13 SM.
It could be that it's a different PID number for non PP cars. If someone with access to FORScan could take a look into the PCM and see if you get a reeding.
2012 Pearl White CTS-V Stock
wasinger3000
I'm going to poke around with FORScan tonight and see. I might need some help finding it but I'll let you know when I try tonight.
13' GTCS, will be missed.
jmr061
I took a look and in several places the 2013 Service Manual states "if equipped" when referring to the PTU temp sensor.  I believe it only exists if the car has a PTU cooling system.
I did see this in the service manual as well:
"Heat Protection Mode
During very extreme off-road operation, the AWD system utilizes a heat protection mode to protect the ATC solenoid (part of rear axle) from damage. If the system detects an overheat condition, it enters a locked mode. If the heat in the system continues to rise once in the locked mode, the 4X4 control module disables the ATC solenoid. Allow the system to cool down at least 10 minutes with the ignition switch in the ON position. "
Jason
16 Edge Sport
ShoBoat
Quote from: jmr061 on July 08, 2014, 10:26:13 AM
The second statement seems to point to temp sensor (or limit switch?) somewhere. It could be similar to the oil pressure switch, that simply reads low (or in this case hot) if it's triggered.
Last I heard the cooling system is on there if you have either the PP or Police version.  Out of luck if you have the non-PP version.
ShoBoat
Quote from: SHOdded on July 08, 2014, 01:58:43 PM
True, however I was thinking if there is some sort of thermal protection on the units for non pp and pre 2013 it must have a temp sensor on it? Well you would think, maybe in the rdu?
ecoboostsho
I think there is only thermal protection on the 2013 + cooled units...aka PP. Not positive though and would be happy to be proved wrong!
jmr061
Quote from: ecoboostsho on July 08, 2014, 07:12:22 PM
Go get it stuck and heat the heck up out of the drivetrain trying to get out. That will tell u lol
Jason
16 Edge Sport
MDesign Performance
Thermal protection and a cooler for the fluid would be nice but honestly the best form of preventative maintenance would be to spend $100 a year on a high quality fluid swap. For a measly $100 or less a year you can have fresh, high quality gear oil and the peace of mind that comes along with it. Not to mention not only will your car perform better but <$100 is a lot better than $1,000+ for a new PTU.
sales@mdesignperformance.com
www.mdesignperformance.com
wasinger3000
How often are we thinking the oil should be changed?  I'm quite hard on my car. Lots of data logs back to back at wot ect... I'm going to change mine tonight and see how degraded the oil is.
wasinger3000
The most i can get out of this thing is like 3 ounces..... wheres it all hiding at....
I assume it just turned into a paste and its sticking to the walls.
How many miles are on this fluid? 3 ounces? That's insane.
Certainly a possibility that it is heavy sludged. I can't think of anything else to try, other than to fill it as much as possible, run it for a hundred or two hundred miles, and then attempt to drain again.
If it really is that bad, it may take a few drains and refills to flush it out.
wasinger3000
Quote from: IHeartGroceries on July 09, 2014, 10:56:46 PM
I managed to get 8 ounces out of it. Maybe 9 with what in the hose. I put a camera in and looked around.  It was bone dry after the 8 ounces i pulled out.
I managed to get 10 ounces in. So idk where the other 8 ounces are supposed to go. Manual says 18 ounces.
My car is at 21,xxx right now. Sludge was thick on the cap as well.
jmr061
Can you record the video?
Jason
16 Edge Sport
