Power Transfer Unit (PTU) Equipped Vehicles*** READ THIS
Started by MDesign Performance, July 07, 2014, 10:34:10 AM
explorergotoluvit
2013 explorer sport
LMS tuner stat 160 3 bar magna flow v8 91 map
k&n H&R spring
retrofit FXR bi-xenon projectors done by lightwerkz
all lights replaced with leds from daytimebrightlites
Soon. I'm at 14.5K miles now. I plan to tackle this before the oil has degradated to the point it has sludged.
I'll throw together a how to. I have a '13 with PP.
Sent from my SM-P600 using Tapatalk
jmr061
I put the 2013 SM section on draining and filling on my FTP.
FTP:kb9kst.com:29440. User is "Taurus Club" and password is "2013"
Jason
16 Edge Sport
elund126
2010 Tuxedo Black SHO
Windows Tinted, SP-534, 3-bar, Unleashed Tuning
jmr061
Quote from: explorergotoluvit on July 07, 2014, 11:03:07 PM
does the explorer have a PTU? what is it?
I added the same SM section for the 2014 Explorer. You have a PTU if you have AWD.
Jason
16 Edge Sport
wasinger3000
Are there any additives that will help prevent oil degradation in the PTU?
Is there a temp sensor for the PTU?
13' GTCS, will be missed.
jmr061
Yes there is a temp sensor. The car becomes front wheel drive when you overheat it. Lol don't ask how I know.
Jason
16 Edge Sport
Yeah, VI improvers are added to base stock oils by the manufacturer. I think the design of the PTU is what needs improvement. It is delivering torque to the front axles and the the rear driveshaft continuously of a 4500 lb car, using only a pint or whatever ridiculous capacity of oil. What remains to be seen I think is the effect on oil longevity with auxiliary water cooling equipped on interceptors and PP trim SHOs vs. non-cooled. Water cooling isn't even necessity. If you've got decent capacity, you can rely on a cooler, or even just cooling vanes on the housing to keep things cool. I've heard it's a headache to add the aux water cooling after-the-fact. Maybe it'd be easier to plumb in an inductive auxiliary oil cooler/radiator?
ShoBoat
#23
There is a procedure for the 13+ PP cars with liquid cooling. There is a fill and drain plug. According to the shop manual you have to remove the passenger cat to access the fill plug. I have yet to try this. I'm going to attempt it this weekend.
I have seen in FORScan the PID for the PTU temp gauge and the Lube life monitor (only available on 13+ PP) . I am still working on the equation for Torque Pro.
2012 Pearl White CTS-V Stock
wasinger3000
Quote from: jmr061 on July 08, 2014, 01:10:36 AM
Hah. Sounds like a good time. Does it display any warning light? Or are we just left to figure it out on our own?
wasinger3000
Quote from: ShoBoat on July 08, 2014, 08:36:45 AM
Would the non PP guys be able to use a PID for the temp?
ecoboostsho
Quote from: wasinger3000 on July 08, 2014, 09:01:11 AM
Nope...there isn't a sensor to even read the temperature.  I have a 2011 PP and it doesn't have a sensor either.  The cooling and temp sensor was only added to the 2013+ PP
wasinger3000
Quote from: ecoboostsho on July 08, 2014, 09:07:19 AM
Lovely.... is it that much to as for a temp sensor in for something so fragile yet important. >:(
I wonder if they would deny a warranty claim on this part if they dig to see if it has been tuned.
jmr061
To me not having a temp sensor is odd. How would it know it's overheating. Let me look into the 13 SM.
Jason
16 Edge Sport
ShoBoat
With mine that has the cooling, I have seen temps as high as 95c (208f) when I'm driving a little harder. But most of the time is slightly below engine temps.
