Ecoboost Performance
Troubleshooting, Maintenance, TSB Articles
Troubleshooting
clicking when backing up
Started by sunwolf, August 25, 2014, 09:08:20 PM
sunwolf
Sr. Member
Ecobooster
Last Edit
: August 25, 2014, 09:10:17 PM by sunwolf
Just today I noticed my car makes a clicking sound when backing up if I hit the gas. It makes a couple clicks like some gears are sliding into place then stops for as long as i back up. When I start going foreward it clicks again but after that it wont make the noise until I use reverse again. Has anyone seen this problem? I have LMS tune as my only mod. Could this have damaged my trans or something already at 5K? I will try to upload a video later if this helps.
EDIT: This is not when turning. It happens during turns or straight lines so I would think it is different from the issue covered in the thread below.
2014 Taurus SHO Black Performance Pack LMS tune 3bar tstat downpipes
2008 BMW M6 Convertible SMG
2008 F-150 XLT 4x4 5.4L
2011 F-150 Ecoboost Crew Cab 4x4
2012 Lincoln Navigator L 4x4
Forum Supporter
Forum Supporters
Trap Speed of almost 116 mph.
Re: clicking when backing up
August 25, 2014, 10:05:17 PM
Last Edit
: August 25, 2014, 10:16:55 PM by ZSHO
I dont think its tune related,try returning the car back to stock for a while and see if it happens again and proceed from there,also check if there are any DTC codes on the my cal tuner?
2013 Performance Package SHO| Livernois Custom Methanol Tune|3-Bar Map|Reische-170-Stat|Full Race Tial-10psi BOV in Black|PPE-Gloss Black Hot Pipes|EPP Dual Intake in Gloss Black|PPE Catted DP|Corsa Sport Cat Back Exhaust|H&R Sport-Springs|CFM Performance Billet Valve Cover Breather In Gloss Black|Llumar 20%Ceramic window Tint|MSD Ignition Coils in Black|Extreme Roof Spoiler|Redline Fluids all around|Gearhead Intercooler|
First-SHO With Direct Port Alky-VP-M1-100%-Methanol Injection|LMS-Custom-Dyno-Tuned
@ 415whp-465wtq|
Best Trap Speed of 115.54 mph|
Forum Supporters
August 25, 2014, 10:23:18 PM
Too early to have problems! Possibly the RDU (low fluid perhaps?) if sound is coming from the rear. Did you get a halfshaft recall notice?
booooost
August 26, 2014, 09:01:52 AM
Wheel bearings? ??
Troubleshooting
