Torque PIDs...Take 2
ShoBoat
Quote from: 66 Galaxie on June 24, 2015, 09:41:48 AM
Can anyone confirm tire pressure data does or does not work on 2013+ or are the PIDs different?
I haven't had success on my '14 Flex using the custom PID info posted earlier in this thread.
On the 13 SHO I can confirm that it does work and reports the correct tire pressure. The PIDs earlier in this thread are the correct ones.
2012 Pearl White CTS-V Stock
pejohnson
I can confirm tire pressures work on my 13 as well.
13 Platinum White, PP, 402A, Moonroof, Multi-contour seats, and Navigation.  MODS - LMS 93 octane 3bar tune, 160 LMS thermostat, Airaid CAI, 15% tint, interior LED upgrade, LED puddle lights, Nurburgring 20" Gloss Black Powercoated Rims, H&R springs, Corsa catback exhaust, LMS catted downpipes
Best time 1/4 mile 12.588 sec @ 109.44 mph
wasinger3000
It works on my 13 as well.
13' GTCS, will be missed.
66 Galaxie
Thank you all for the confirmation.  I'm going to rebuild the custom PIDs and see if it works; however, I may be limited by the capabilities of Enginelink running on my iPhone, we shall see.
66 Galaxie
Are tire pressures always available in torque or do you need to be driving and/or drive a minimum time/distance for the data to be available?
twnscrw13
Quote from: wasinger3000 on February 08, 2015, 02:06:08 AM
Tested and confirmed working. I let air out of each tire to make sure it changed. It did, I then aired it back up and shows a steady pressure now. Pretty cool.. glad I tried it.
What PID/formula did you use?
2018 PP, blue. Sony, Navi. Stock.... For now.
twnscrw13
Quote from: FoMoCoSHO on June 10, 2015, 11:00:46 PM
Quote from: ShoBoat on June 10, 2015, 09:36:15 PM
Just tested the AWD PID seems to work as advertised. Interesting as the rear seems to jump to over 80% as soon as you step on the pedal from a dig. Even with light acceleration.
That is what I see in my gauge....any provocation of the happy pedal moves power to the rear first.
I've played with the pid and I'm not getting a response (little green light). What PID, header, equation are you using?
66 Galaxie
I have had luck using the AWD% PID and formula from a few pages back on my '14 Flex:
Long Name AWD PWM Modulation of rear
Short Name  AWD %
PID  22d128
Equation  A/256*100
Min Value  0
Max Value  100%
Units Header 761
twnscrw13
Quote from: 66 Galaxie on June 25, 2015, 11:32:26 PM
Short Name  AWD %
PID  22d128
Equation  A/256*100
Min Value  0
Max Value  100%
Units Header 761
Using those values I get
  Result for equation: No response
  Command: 22d128
  Response: NO DATA
Using the 726 header I get
  Results for equation: No response
  Command: 22d128
  Response: 7F2231 (I get the same if I use 221e63 as the PID)
66 Galaxie
Hopefully a veteran Torque user will chime in to help you.  I'm using Enginelink on my iPhone which seems to work with some of the custom PIDs that have been figured out for Torque.
In terms of my tire pressure challenges the formulas I'm trying are:
Long Name  LFTire Pressue  RFTire Pressure  RRTire Pressure  LRTire Pressure
Short Name  LF Pressure  RF Pressure  RR Pressure  LR Pressure
PID  222813  222814  222815   222816
Equation    (((256*A)+B)/3+22/3)*0.145 (same for all)
Min Value  0 (same for all)
Max Value  70 (same for all)
Units psi
Header  726 (same for all)
ecoboostsho
The tire pressures come from the BCM in the 13+ vehicles. I'm wondering if engine link isn't talking to the right module...that's what the header is for. Only thing I can think of...
66 Galaxie
Interesting.  I will try to test it on a pre '13 car when I get a chance and see if it works.
ecoboostsho
Unfortunately in pre 2013 cars there is a smart junction box not a BCM so you can't get tire pressures unless your adapter and software can handle medium speed CAN. (MSCAN) as opposed to HSCAN. Torque can't so we don't get tire pressures on the 2010-2012s. FORSCAN can read them though.
66 Galaxie
I see, thanks!  I believe my limitation is either the Enginelink app or the WiFi adapter needed for an iPhone.  If I ever run into a solution I will let everyone know.
Thanks again!
So have these new gauges all been added to the bulk file?
