Torque PIDs...Take 2
Don't know why but I'm digging the blue.
ecoboostsho
Updated the knock PID on the 1st page due to research in other thread here...
http://www.ecoboostperformanceforum.com/index.php/topic,1448.0.html
Think I'm happy with this setup for now. Notice the 0.1 hp I pulled by dropping the tablet...lol
ShoBoat
Quick question, I just moved all my stuff to a newer Galaxy. And this PID Trans Temp TaurusTrans Temp221e1c(((signed(A)*256)+B)*(9/8)+320)/10-40300Deg is showing F? I copied the equation over exactly. Any ideas?
2012 Pearl White CTS-V Stock
ecoboostsho
Quote from: ShoBoat on August 13, 2014, 03:17:26 PM
I believe if you set the global units variable in Torque to Deg. C (*if it isn't already) and that may change it?  The equation as is will definitely read in Deg. F.  Worst case you could take the whole thing and multiple by .5555 and add 32 to get to Deg. C .
ShoBoat
Any suggestions for gauge to replace timing adv.
ecoboostsho
Quote from: SHOnUup on August 14, 2014, 12:04:08 PM
What exactly are you after? Can you be more specific?  Are you looking for a different PID for timing advance or a different style gauge or something else?
Not really sure, hence the ask.
ShoBoat
Ok I didn't see these in the spreadsheet. I have used these in FORSCan a few times and they good to have as a diagnostic tool.
1 misfire count. This tells you the number if misfires you have had during the current drive cycle. Sine the car was started last.
PID 220345
Name Misfire Events
Short MSF Event
Equation B
2 misfire trips. This one tells you how many drive cycles since the last time it's had a number of misfires. I believe you need at least 5 to trip this to zero.
PID 2216dc
Long Misfire Trips
Short MSF trip
Equation B
It looks like these are just dependant on the B variable and it look correct. However I can't test the first one completely as I haven't had any in a while. If someone could confirm that would be awesome.
What max should I put on this?
ShoBoat
200 for both, it doesn't really matter that much as you won't be using a gauge with a dials just the numerical gauge is good.
Quote from: ShoBoat on August 17, 2014, 10:39:47 AM
Thanks, "was" gonna use a half dial with the low and high keepers to stay with my theme.
Gauge shows activity with the blinking square but no misfires to report on.
ShoBoat
Quote from: SHOnUup on August 17, 2014, 04:07:13 PM
That's a good thing, did you check the other one? Misfire Trips?
