Torque PIDs...Take 2
ShoBoat
2012 Pearl White CTS-V Stock
Larrylu
Quote from: wasinger3000 on August 03, 2014, 12:13:15 PM
Larry what skin is that?
That skin is Bulletproof. I admired ShoBoat's and he passed the name to me.
Larrylu
Speaking of getting turned around with this plus and minus knock retard thing, forget my initial attempt to duplicate my + 7 reading. I got a bit nervous worrying about the reading and my highway speed testing is bogus because I got turned around myself. I'm now pretty sure I was generating minus readings with my highway cruise. Got to get my head straight and start testing all over again.
Larrylu
First thing I decided to flash back to stock for my upcoming dealer visit and a little comparison knock readings over the next couple of days. Oh no.....the MyCal Touch won't load the stock file. It says "Invalid File" and the code "CRC". I tried twice same results. Since I already had swapped out the 3 BAR for the stock 2 BAR, I figured I'd try to load my old Stage 4+  2 BAR  170 TStat. That loaded perfectly first time and I reset my knock retard gauge and drove off to gas up. I noticed my learned octane was at 134 (from usual 100). By the time I got to the station the learned octane was 124. I gassed up then headed home with the learned octane steady  at 124. So far my knock retard readings are -4 and +0   I'm particularly worried about not being able to load my stock tune file. Any one have any similar experience/advice?
Quote from: Larrylu on August 03, 2014, 08:18:19 PM
Might try disconnecting battery with 2 bar on and see if that helps.
Those knock readings are right on with mine on the 4++ tune from LMS.
Larry... Likely the stock tune file has been corrupted... Contact Anthony at LMS and get a new copy of the stock tune.
Could be your OBD link adapter possibly giving you issues with loading the stock tune,i have the MX adapter and just skeptical when to many adapters are plugged in theOBD port and could affect or intefere with the ECU causing you to have issues returning the car to stock.
Quote from: Larrylu on August 03, 2014, 11:38:10 AM
As requested here is a bigger pic of my current main screen display. I think it's the best I've had so far, but if I've learned anything about myself...it's that I can't leave well enough alone.
Think that's the "trailblazer" theme. Bulletproof has bright green numbers.
Thinking the background is a bit bright in this one?
Larrylu
Quote from: Larrylu on August 03, 2014, 06:47:33 PM
I looked up the PM and I'm pretty sure ShoBoat said Bulletproof, found it, used it....TrailBlazer does not ring a bell. Now my wife would agree that I'm often wrong so if that's the case here, I apologize for the bum steer.
Quote from: Larrylu on August 06, 2014, 01:46:28 PM
Totally fine...you have inspired me at the least....wish the needles were color changeable
Larrylu
Quote from: SHOnUup on August 06, 2014, 10:19:18 AM
I took a cell pic with the flash off in the dark to create an easily importable black background.
