Torque PIDs...Take 2
wasinger3000
This is all i have... Wonder if its just not there or if its cause im using a non MX obd. I dont think its adapter related if i am able to see so many others.
What is the PID for the AWD %?
Anyone else with a non PP 13 have any transfercase PID's?
13' GTCS, will be missed.
ShoBoat
I just checked our 2011 explorer and it wasn't there either. I guess they didn't install one on non liquid cooled PTUs.
2012 Pearl White CTS-V Stock
wasinger3000
Quote from: ShoBoat on July 09, 2014, 12:12:45 AM
Damn... Knew i should of got the PP.... hah.
Thanks for the late night help!
ShoBoat
Anytime.
Quote from: wasinger3000 on July 09, 2014, 12:09:48 AM
Some 13s didn't have the awd pids loaded from factory. You might check into that as mine had to have them added.
ecoboostsho
Quote from: FoMoCoSHO on July 09, 2014, 07:37:49 AM
Weird!?  Is that something the dealer would do?
ecoboostsho
What modules can you see in total?  When Forscan connects initially it should list all of the modules you can see.  Do you just see the PCM?  You can click on a couple of tabs on the initial start up page and get a list.  If you don't have the MX (or something that can read MSCAN) then you won't see all of those modules but I would think the 4x4/AWD modules would be HSCAN (assuming you have the PIDs loaded from the factory.  You appear to be poking around the PCM module from the list of the PIDs displayed?
wasinger3000
Quote from: ecoboostsho on July 09, 2014, 08:04:54 AM
Yup.
ShoBoat
Quote from: FoMoCoSHO on July 09, 2014, 09:00:11 AM
Yup.
Good luck with that.... Unless you can give them the exact procedure.
wasinger3000
Hah. Yeah. I don't see that going smoothly. So if I don't have these PID's does that mean if I try to get my awd gauge activated ( one on the dash display) they would have to add these as well?
Not only will your gauge not display but if there is an issue, the are no pids to communicate a problem.
There is a tsb, and its a pretty simple deal.
ShoBoat
Quote from: FoMoCoSHO on July 09, 2014, 09:39:00 AM
Would you happen to know the TSB number?
Quote from: ShoBoat on July 09, 2014, 09:49:21 AM
I have already contacted High Command and am waiting for her response...
I have all the reports for my car at home so if I don't hear anything I will post up this evening.
wasinger3000
#329
Well is that a load of crap.... so is it all SHO's without the PP. Or is it hit and miss? I want to know if my PTU is going to grenade and it would be nice if my car could give me a heads up before it goes. If it goes... I dont like uncertainties.
