Even though I don't have an ecoboost engine (2011 German built Ford Focus Titanium) in Australia, my search on the web for torque PID have led me here, and it is here that I have found the most help. So I would like to return in kind with a few PIDs that may help:
If anyone can get the equation or verify them, it will help the community tremendously.
steering wheel angle
223302
HEADER = ABS
FORMULA = "((signed(A)*256+b)/10-780"
lateral angle (g)
222b0c
HEADER = ABS
"SIGNED(A)"
BFLHP Brake fluid line hydraulic pressure 9kpa)
222b0d
Transmission Gear Engaged
221e1f
Tells you which gear is engaged (this jumps because we have dual clutch system i am guessing)
Gear command by Output state
221e12
GIVES GEAR RESULT 0,1,2,3,4,5,6
In Gear?
221e04
- 621e0400000000 = No
cataylst temp
22f43c
"((A*256)+B)-40"
fuel level
22f42f
(A/255*100)
torque control request
2203af
- 6203af0c = anti-theft
maX diff btw TP1 AND TP2
2203A7
6203A700 = 0 DEG
INLET AIR TEMP FAULT
220700
0800000 = NO FAULT
ENGINE TOTAL DIST (STARTUP?)
22DD01
LEARNED RELATIVE OCTANE ADJUST
2203E8
DCEC = 54.81%
"A/256*100"
CLUTCH A SLIP (REV/MIN)
221EBB
"((A*256)+B)*(1/4)"
CLUTCH B SLIP
221EBC
"((A*256)+B)*(1/4)"
TRANS AXLE (GEAR RATIO) MEASURED
221E16
F143 = 15.079:1
((A*256)+B) / 4096
726 Header - for battery stuff
BATT AGE
224027
"((A*256)+B)"
BATT CHARGE
224028
"A"
BATT TEMP (c)
224029
"A-40"
IN CAR TEMP (BCM)
22DD04
HEADER = 726
FORMULA = "A/8"
OUTTEMP
22DD05
LATERAL G
222B11
HEADER = ABS
"((signed(A)*256)+B)*0.02"
LONGATUDE G
222B0C
HEADER = ABS
CLUTCH A OPEN
221EA0
1 = YES
621EA000010001
ACC COMP STATE
22099B
0000= OFF
ACC PEDAL POSITION %
22032B
"A/256*100"
