October 15, 2019, 10:11:17 PM
Author Topic: Torque PIDs...Take 2  (Read 293012 times)
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
Re: Torque PIDs...Take 2
« Reply #765 on: May 22, 2019, 08:40:33 AM »
I was recently looking for a way to detect knock and was pointed to this awesome thread. I followed the instructions and installed four of the custom PID's. Most don't work and the AWD one throws a constant value. What am I missing?
I have not read all 51 pages of this thread, do these work on the 2010 SHO?
Attached are pics of what I am seeing and what I get when I "test" the Knock PID.
2010 - Unleashed Tune - Corsa Exhaust - 275/40-R20 - H&R Springs
Offline ecoboostsho
  • Forum Supporter!
  • : Minneapolis, MN
  • -Given: 190
  • -Received: 239
« Reply #766 on: May 22, 2019, 08:47:44 AM »
It should definitely work on a 2010 Taurus. I'm assuming you can get the standard gauges (say like (RPM) to respond? I just want to make sure your adapter is actually talking to the car properly.  Also can you send a screenshot of your custom pid screen in Torque? Just close that error message window for starters.
Sent from my Pixel 3 XL using Tapatalk
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
« Reply #767 on: May 22, 2019, 09:10:28 AM »
All built-in Torque Real Time Monitoring gauges work.
The AWD one throws a number, but why is it always at 50.4?
Attached is a pic of the Knock PID.
Thanks !
Offline SM105K
  • : Arizona
  • -Given: 634
  • -Received: 767
  • Land Yacht Pilot
« Reply #768 on: May 22, 2019, 09:22:28 AM »
Jman,
adjust your minimum value to -7.0
adjust your maximum value to 7.0
make sure your scale factor is x1
then test
"M" 2013 SHO PP: AJPTurbo E30 Tune, GH Intercooler, PPE Downpipes, Dicunzolo Gen2 Trans Mounts, UPR Catch Can, K&N Drop In, H&R Springs, Power Stop Brakes, Curva Concept C7's.
"The Go Cart" 2013 Focus ST: AJPTurbo Flex Fuel Tune, Megan Racing Downpipe, Boomba BOV, and Short Shifter.
Offline Gjkrisa
  • : Fairbanks, AK
  • -Given: 913
  • -Received: 188
    • Photos
« Reply #769 on: May 22, 2019, 10:17:30 AM »
Thanks !
I see that's for knock and your main issue was with awd I believe just making sure your scale factor is 1x should fix the issue that's how mine is and works
Offline ecoboostsho
  • Forum Supporter!
  • : Minneapolis, MN
  • -Given: 190
  • -Received: 239
« Reply #770 on: May 22, 2019, 10:55:06 AM »
Thanks !
If the previous suggestions don't work just delete your equation and temporarily put in an A for your equation. You should at least get a value back that is non scaled. That will help narrow down the problem for me...
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
« Reply #771 on: May 22, 2019, 11:15:15 AM »
I changed the scale limits and verified that all PID's are set at x1. Still no luck.
I'll try deleting the equation and report back,
Here are some additional pics and also the Bluetooth thingy I am using. As you can see, built-in Torque ones do work.
« Last Edit: May 22, 2019, 11:20:13 AM by jman »
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
« Reply #772 on: May 22, 2019, 05:02:07 PM »
Replaced the Knock equation with an A, same response when tested: NO DATA.
Offline ecoboostsho
  • Forum Supporter!
  • : Minneapolis, MN
  • -Given: 190
  • -Received: 239
« Reply #773 on: May 22, 2019, 05:05:54 PM »
Okay well then something isn't communicating with the car properly or the pid is wrong somehow for your car. It looks like it but that is "zero" in the 2203EC correct? It's been a long time since I messed with torque pro (I use obdlink) so I don't think it matters but try a capital EC just for fun. Also what is in your header field?
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
« Reply #774 on: May 22, 2019, 05:12:42 PM »
Yes, two, two, zero, three.
I've tried uppercase before, it auto turns back to lower case.
Header is blank.
« Last Edit: May 22, 2019, 05:14:29 PM by jman »
Offline ecoboostsho
  • Forum Supporter!
  • : Minneapolis, MN
  • -Given: 190
  • -Received: 239
« Reply #775 on: May 22, 2019, 05:31:00 PM »
Header is blank.
Okay just checking. Try using AUTO in the header. If that doesn't work I'm stumped unfortunately. I would try a different app just to see if it's something weird in your Installation of torque.
Offline jman
  • Full Member
  • : Ontario
  • -Given: 26
  • -Received: 25
« Reply #776 on: May 23, 2019, 07:12:50 AM »
Neither the "A" or the "auto" fixed it. :(
Weird thing is that the AWD does return a value (steady 50.4) but all others don't.
When I was playing with Forscan I read that the 2010 doesn't have a BCM (or cannot be accessed), could this be why?
Offline ecoboostsho
  • Forum Supporter!
  • : Minneapolis, MN
  • -Given: 190
  • -Received: 239
« Reply #777 on: May 23, 2019, 07:47:24 AM »
Well on the 2010-12 there is a smart junction box (SJB) on the MSCAN bus and not a BCM on the HSCAN bus.  First your adapter has to have the ability to speak MSCAN (medium speed CAN bus) and second Torque can't (to my knowledge) access both the MSCAN bus and HSCAN bus at the same time.  That said if I recall correctly the AWD gauge is actually reading the AWD module (not a SJB or BCM) and that is why the header needs to be "761" for that gauge.
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
