April 17, 2021, 04:56:21 AM
Author Topic:  MDesign Dual Carbon Fiber Cold-Air-Intake (DEVELOPMENT PHASE)  (Read 35300 times)
Offline MDesign Performance
  • Vendor
  • Sr. Member
  • Dearborn, MI
  • Thank You
  • -Given: 117
  • -Received: 122
  • Owner of MDesign
    • MDesign
  • Liked:
  • Likes Given: 0
Re: MDesign Dual Carbon Fiber Cold-Air-Intake (DEVELOPMENT PHASE)
« Reply #15 on: June 07, 2014, 12:15:58 AM »
LMS is just down the street from me so I plan on getting in there some time in the near future.
Seriously? I was up there earlier today. I'm maybe 5-10 minutes from them
I'm in Dearborn as well, I think I might've spotted you today down Ford Rd? I'm free this Sunday if you want to check it out in person, check your PM's.
sales@mdesignperformance.com
www.mdesignperformance.com
Offline BBOX
  • Full Member
  • Streamwood, IL
  • Thank You
  • -Given: 86
  • -Received: 29
  • Liked:
  • Likes Given: 0
« Reply #16 on: June 07, 2014, 12:35:36 AM »
Honestly from a purely aesthetic perspective $600 seems like a good price, so for someone that likes to show off their car I think it's worth it for that aspect alone. If you bring dyno-proven results that demonstrate an improvement with it, you're gonna have a hell of a deal.
Offline SwampRat
  • Forum Supporter!
  • RotM Winner
  • Elite Member
  • Tulsa, OK
  • Thank You
  • -Given: 311
  • -Received: 197
  • 2013 SHO SHONUFFBOOSTED
  • Liked:
  • Likes Given: 0
« Reply #17 on: June 07, 2014, 02:16:41 AM »
I agree 100 % with BBOX  ... this looks very promising .
2012 AWD EDGE Sport ... Kona Blue
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 13039
  • -Received: 4242
  • Liked:
  • Likes Given: 6
« Reply #18 on: June 07, 2014, 04:31:55 AM »
These improvements include dual intake filters for each turbo with genuine carbon fiber canister heat shields, ceramic coated aluminum hard-piping which retain both factory vacuum nipples and the MAP sensor, and each filter has it's own flexible tube to allow a source of fresh air from wherever the user defines.
I'd say these improvements in function & looks justify the price point.
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 705
  • -Received: 1157
  • The Tenth Man
  • Liked:
  • Likes Given: 1
« Reply #19 on: June 07, 2014, 09:18:47 AM »
I think it represents a good value as is and if it makes 15-20 HP it will be an outstanding value.
I am curious about the decision to go with 2 air sources. Not sure its necessary and it adds complication and dollars to the design.
Overall hugely promising.
  • Vendor
  • Sr. Member
  • Dearborn, MI
  • Thank You
  • -Given: 117
  • -Received: 122
  • Owner of MDesign
    • MDesign
  • Liked:
  • Likes Given: 0
« Reply #20 on: June 07, 2014, 10:55:11 AM »
The reason of going with two air sources was to mimic a "sequential" effect with the turbo system. With the shorter and restriction-less (as in no vacuum nipples or intrusions in the piping) front intake piping the front turbo should spool quicker than the rear turbo. This idea is derived from sequential twin-turbo systems where a smaller, faster spooling turbo supports the lower RPM band while the larger second turbo takes it's time to build and achieve full boost.
The concept is similar to RX's Sequential Boost system just on a smaller scale, more like a throw-in, added benefit.
As far as the 2 different sources of air, I decided to retain the OEM hood/ram air source while adding a second user defined ram-air effect to the other. The way I have the fresh air sources currently configured are where the front turbo receives it's flow out of a modified OEM intake hood snorkel and the rear turbo receives air flow from the lower front bumper area. Every part of the design was thought out and serves a purpose as with the exhaust system.
The intake was meant to be a solution for a cold-air intake system so it was function over appearance first and foremost. As some humor, of the select few who have seen the first design the process was like Tony Stark building the Iron Man, first suit ugly but functional and got more aesthetically appealing after each revision!
« Last Edit: June 07, 2014, 11:22:45 AM by Spartn27 »
Offline BBOX
  • Full Member
  • Streamwood, IL
  • Thank You
  • -Given: 86
  • -Received: 29
  • Liked:
  • Likes Given: 0
« Reply #21 on: June 07, 2014, 01:45:55 PM »
So you've got an intake an exhaust, are downpipes in the works? :)
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 705
  • -Received: 1157
  • The Tenth Man
  • Liked:
  • Likes Given: 1
« Reply #22 on: June 07, 2014, 02:02:14 PM »
I see a specific void spartn is filling with the first two products. II'm not sure such  a void exists with downpipes. PPE, Livernois, and stainless works have us pretty well covered. IMHO.
Offline BBOX
  • Full Member
  • Streamwood, IL
  • Thank You
  • -Given: 86
  • -Received: 29
  • Liked:
  • Likes Given: 0
« Reply #23 on: June 07, 2014, 02:10:05 PM »
What void? There are multiple intake and exhaust options that already exist.
Sent from my Nexus 5 using Tapatalk
Offline FoMoCoSHO
  • Super Moderator
  • Elite Member
  • Thank You
  • -Given: 705
  • -Received: 1157
  • The Tenth Man
  • Liked:
  • Likes Given: 1
« Reply #24 on: June 07, 2014, 03:46:41 PM »
Current intakes are useless and some of us are not fond of the sound/price of any of the current exhaust options.
  • Vendor
  • Sr. Member
  • Dearborn, MI
  • Thank You
  • -Given: 117
  • -Received: 122
  • Owner of MDesign
    • MDesign
  • Liked:
  • Likes Given: 0
« Reply #25 on: June 07, 2014, 05:23:04 PM »
^^ This really, I was actually interested in purchasing a set of PPE downpipes myself! So as of now no downpipes in the works.
Offline BBOX
  • Full Member
  • Streamwood, IL
  • Thank You
  • -Given: 86
  • -Received: 29
  • Liked:
  • Likes Given: 0
« Reply #26 on: June 07, 2014, 06:01:47 PM »
Fair enough, I'm looking to buy downpipes as well but would have been willing to wait if MDesigns was gonna come up with something that way too, right now I'm VERY interested in the intake and exhaust.
Offline J-Will
  • Elite Member
  • Thank You
  • -Given: 68
  • -Received: 106
  • Ecobooster
  • Liked:
  • Likes Given: 0
« Reply #27 on: June 07, 2014, 08:14:53 PM »
Are the hard pipes you refer to in your new setup, the same as hot pipes or the noise eliminator pipe?
3-bar
SP-542 plugs w/ GH gap
Offline yowen
  • Full Member
  • Grand Rapids, MI
  • Thank You
  • -Given: 13
  • -Received: 23
  • Ecobooster
    • Ford F-150 Blog
  • Liked:
  • Likes Given: 0
« Reply #28 on: June 08, 2014, 06:11:50 PM »
Do this cause any change in the way the car sounds? Or, aside from VTA, does it sound pretty much stock since you went with a sealed design?
2010 Taurus SHO, Tuxedo Black
Awaiting Installation: Catless Downpipes, LMS Tune, 3Bar Map Sensor
Offline BBOX
  • Full Member
  • Streamwood, IL
  • Thank You
  • -Given: 86
  • -Received: 29
  • Liked:
  • Likes Given: 0
« Reply #29 on: June 08, 2014, 06:15:48 PM »
Out of curiosity, how loud is the BOV when it vents to the atmosphere?
* Recent Topics
Re: 2014 MKS ignition coils?
by avidmotion | April 16, 2021, 10:00:37 AM
I like MSD, smoothed out idle and got rid of a slight studder mid thro...
Re: Just another new old guy.
by H82bbad | April 16, 2021, 08:02:44 AM
Well if your askin youíre one of us 😂😂 Iím only 55. &#...
by wraitherx | April 15, 2021, 05:49:33 PM
Put the summer wheels back on Sent from my iPhone using Tapatalk...
What's New at RockAuto
by RockAuto | April 15, 2021, 02:23:35 PM
There's something for everyone!  From luxury all-weather flo...
by bpd1151 | April 15, 2021, 12:42:44 PM
04/15/2021......Welp.... having had some time to process and put behin...
Re: Tracking an oil leak
by djshew12 | April 15, 2021, 10:14:11 AM
This final post is for posterity.It was indeed a bad oil pressure send...
Re: Picked up an 18 Navigator
by 4DRHTRD | April 14, 2021, 05:09:06 PM
Did some updates to the Navi, she got some damage and had to have the ...
Re: Did some updates on the Ecopowerparts shop truck
by Macgyver | April 12, 2021, 09:40:09 PM
Oh sick stuff right there....
Re: Trans "leak" from vent in fill cap
by Cobra93 | April 12, 2021, 04:54:01 PM
I found a replacement dipstick/cap for $11.52. I think I'll try t...
Re: Another CO XSport
by Macgyver | April 10, 2021, 09:09:29 PM
Welcome and thanks for posting  pics of the Ecoboost....
