Downpipes for Flex/SHO/Explorer V6 Ecoboost/Lincoln MKT/MKS
Started by EcoPowerParts, February 15, 2013, 02:40:29 PM
PopolZ
Quote from: EcoBrick Bob on April 24, 2013, 12:00:59 PM
Also wondering how much extra sound, and if there's any drone issue.
My NESHO pipe sounds good outside and in the front 2 rows, but is annoying in the third row.
Guess we need more data.  I have decided to wait.
Performance wise I wont be able to tell as I'm getting my downpipes installed and a copy of the NESHO done at the same time. Noise will I'll be able to provide a sound clip/vid when they're installed on Monday so you'll have an idea.
2010 Ford Taurus SHO, non-PP, Steel Blue #243 of 301 - Custom tune by Torrie@Unleashed, PPE non-catted downpipes, custom 3rd cat & resonator delete, water/meth injection, HKS SSQV3 BOV and Carbotech AX6 brake pads.
1991 Nissan Skyline GTR, Pearl Black Metallic - a few goodies
PopolZ
non-catted PPE downpipes, custom 3rd cat and resonator delete.
That's only a few throttle blips but you can hear a bit of turbo whine. I'll try to get another vid while driving tonight or tomorrow.
PopolZ
Quote from: 4DRHTRD on April 29, 2013, 01:16:31 PM
That sounds bad ass! Great job
just went for a test drive with a warmed up engine... well it's the only time it sounds bad ass!
when you start to give it some throttle it sounds like an old GM  V6 2.8l engine which is annoying as F**K! At cruising speed, no drone and if you throttle up a little even with the windows closed you can hear the turbos.
EcoBrick Bob
Sounds like "RICER HEAVEN"!!!!
Can you tell the HP difference?
Naples, FL & Clear Lake, IA
PopolZ
Quote from: EcoBrick Bob on April 29, 2013, 05:02:01 PM
Ricer heaven would be lots of sound and no action... It isn't the case as there's definitely an improvement in engine and boost response but can't really tell about the HP gain as I couldn't push it due to traffic.
I guess I'll have to get a resonator re-installed... the stock mufflers aren't muffling much.
EcoBrick Bob
Have you removed the 3rd cat and the middle muffler?  I have a NESHO X-Pipe.   However,  I can swap it out for stock section in about 30 min.
PopolZ
Quote from: EcoBrick Bob on April 29, 2013, 07:35:23 PM
All I have left are the stock mufflers.
bnoon
I want to run 2.5" pipes to a Magnaflow internal x-pipe muffler in place of the stock third cat/res and see what that sounds like before I choose what to run out back.
EcoBrick Bob
That's what my Magnaflow Street System is like on my 09' G8.
(Kooks middie headers w/cats, x-pipe, mid muffler,  & axlebacks)
For some reason it is louder on the road, but quieter at idle than my 08' G8 (Kooks middie headers w/cats, H-Pipe with stock piping to Magnaflow axlebacks.)
H-pipe seems to have a lower tone note than X-pipe, which likely affects what one hears at HWY speeds.  Both are not obnoxious, unless you really get on them.
PopolZ
Highway driving report: It feels like I've lost some low end torque but it's no slug. You can hear the turbos pretty much every single time you flirt with the pedal. Drove with the back seats down, a tiny witty little bit of drone if you keep the engine at 2000rpm but if you happen to have the radio on just for a bit of background noise you wont hear it.
When the flirting stops and things get a little nasty ohhhh the joy! Hate the sound with a passion between 2600rpm and about 3600rpm but damn that thing is moving!
edit: I've ordered a magnaflow 11379 so it can be added after the x-pipe. hopefully this will remove the gawd awful noise.
edit2: tried to capture the noise with another video but it didn't register...damn wind noise.
bnoon
Finally got a picture of where I had to clearance the rear down pipe.
bnoon
My car definitely  doesn't have that
Sent from my HTC6435LVW using Tapatalk 2
EcoBrick Bob
bnoon- what year is your Flex?   Could there be some minor differences between years?
