Glad to see the (theoretical) simplicity of a valve cleaning mentioned. Removing/replacing the head? What illogical nonsense. Unless, like stated, it is simply for research.
Walnut media blasting is quite popular for clearing deposits in GDI top ends, and has been for years.
Shoot, valve cleaning falls under regular, routine maintenance for the Mazda MZR - manual cleaning, in fact, performed by many owners with little more than wire brushes, solvent and a shop vac.
With or without control measures, such as OCCs, you should still consider valve cleaning as a routine, PITA piece of maintenance. AFAIK, it is for all turbo GDI.
