Larrylu
Quote from: glock-coma on March 22, 2014, 09:35:17 AM
Installed husky liner floor liners front and rear.
Pretty happy with the fit and finish. I'll have some pics up later
I like mine too, but you really have to be careful handling with those sharp teeth on the bottom.
Brucelinc
I installed my Aeroforce gauge.  I am seeing a spike of 13.6 PSI of boost.  Not sure how accurate that is.  I also ran a 0-60 and 1/8 mile performance measurement.  Ingore the 1/4 mile time - I was not in Mexico so I backed out of it before the end of a 1/4.  It was 11 degrees in my area this morning and I was on a county road with new pavement that gave super traction off the line.  Car was feeling really strong this morning.
Quote from: Brucelinc on March 22, 2014, 12:23:20 PM
Clean install, looks good!  ... excellent 1/8 time!
TSS
Whoa Bruce. Sick 0 to 60 time. I have never hit 13 psi.   I did hit a 60 4.13 though on Friday.   That bested my 4.2.  4.09 on Your First Try is fantastic. .
Brucelinc
That 1/8 is probably a tad too good.  I think I had a bit of a tailwind.  I first ran in the opposite direction just for 0-60 and got a 4.26.  I backed off prior to running the 1/8.  I then turned around and got the run that I posted.  Since I gained almost .2 on the 0-60, I am pretty sure the wind was a factor.  It would have been larger factor in the 1/8 than it would have been 0-60.  The car is strong, though.  :)
Brucelinc
Quote from: TSS on March 22, 2014, 02:58:07 PM
Thanks Todd.  Our posts crossed....As I said, I ran in both directions - got a 4.26 and that smokin' 4.09.  I was pretty aggressive off the line, too.  I was on excellent pavement so I was leaving at 2000 RPM.  I was getting some wheelspin but not a huge amount - got a nice chirp on the 1-2 shift, though.  In this case, I might have been better off to raise tire pressures to lower rolling resistance.
Those MKS's are faster than I thought!
I vacuumed her out and cleaned up a little salt.  When I put the carpeted floor mats back in last night, I noticed it need it.
TSS
/  you are optimistic. I am NOT putting my carpet mats back until mid April.
LOL  I'm hoping the worst is over.  A little snow or salt now won't hurt much.  I'll probably shampoo the mats by May anyway.
So ... who's going to be first to break into the 3's for 0-60???
Dave, I need to shampoo the carpets as well, despite having Weathertechs in place.  To get rid of any odors the winter-crap-on-shoes may have left behind :(
Brucelinc
I am continuing to play with my Aeroforce Gauge and adding additional parameters to monitor.  It is nice to observe the coolant temperature and transmission temp.  Yesterday, I spiked 13.6 PSI of boost ONE time but could never duplicate it again.  I think it was around mid-range (4000) RPM in 2nd.  Most of the time, though, under WOT, it is in the 8-10 range.
I will leave others to break into the 3s on 0-60.  I am pretty comfortable knowing that we all have cars that are among the quickest full sized sedans you can buy.  I wish we had a track in the Twin Cities, though.....:)
TSS
Quote from: SHOdded on March 23, 2014, 12:30:01 AM
I am pretty confident anyone with a tune and meth is there. You just don't hear much about it here because this is a 1/4 mile crowd. :)
And Bruce,  I have not even hit over 11 yet we have very similar acceleration times. I wonder what that means? Only other variable between our cars is my K&N Typhoon.  I have the 528 plugs and I think you do too.
Brucelinc
And Bruce,  I even hit over 11 yet we have very similar acceleration times. I wonder what that means?
[/quote]
Todd, I wonder if the altitude setting on the gauge affects how it registers boost?  I have mine set at 1000 feet for my area.  Also, would barametric pressure impact the vacuum/boost readings?  My max boost readings are not consistent.  Coolant temps range from about 183 - 192, depending upon whether I am moving down the highway or just idling.  Trans temps run much cooler.
watts
Working on a trunk lighting upgrade.  I'm making router templates so I'll be able to duplicate my work if anybody is interested in the same.  I have a 4 year old and a 1 month old, so garage time is limited these days.  Look for a write up in the coming weeks!
2014 Taurus SHO - Sony, Mikko suede, 20" low gloss wheel option.
Weathertech mats; LED interior bulb, puddle lamp, and map light conversion; Custom trunk lighting, Custom subwoofer install, LED DRL kit.
