May 25, 2020, 10:59:20 pm
Author Topic: What have you done to your Ecoboosted vehicle today?  (Read 1872404 times)
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
  • I'm the captain of this SHIP
« Reply #7245 on: November 05, 2019, 12:48:18 pm »
Radiator leak?  Hope just a hose!
My first thought was water pump, but the shroud that encases the radiator had a little drips on it. Unfortunately I don't think it's just a hose but hard telling until I tear it apart!
Offline mrhighcaliber
  • Full Member
  • -Given: 304
  • -Received: 142
« Reply #7246 on: November 05, 2019, 02:02:13 pm »
I don't see the failure mode here, the car works normally with the new PTU.
has anyone broken the output of the trans/input of the PTU to where it just slips?
Lol. There is no failure mode there. At least not from a power handling perspective. These only fail from lack of maintenance. Spun bearings and galling of the gears from lack of lubrication.
High Heat dries up the lighter oil molecules in the lube, which causes more heat due to lack of lubrication (thermal runaway) which leads to the remaining gear oil turning to thick black paste which clogs up the vent tube in the ptu which cause pressure buildup in the ptu which forces the remaining, non-congealed fluid out past the shaft seals. Now the only left is a thick paste thats easily flung off of the gears, sticking only to the case. After this chain of events, the bearings run dry and begin to fail, next are the gears. Tolerances widen or things begin to sieze.  Bearing and gear noise are usually the first signs of mechanical failure.
But the PTU internals are stout. The weakest part of our powertrain is the RDU Atc coupler. (The electronic coupler in the rear differential). At least in terms of tq capacity and power handling.
Sent from my PH-1 using Tapatalk
Offline SM105K
  • Forum Supporters
  • Arizona
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
« Reply #7247 on: November 05, 2019, 02:52:41 pm »
^ that was well put.  Change your fluid gents.  Also protect your PTU from heat at all costs.
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Elimintor | MSD Coils | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Brakes | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline shoNoff
  • NH
  • -Given: 216
  • -Received: 652
  • Shomu the killer whale
« Reply #7248 on: November 05, 2019, 03:42:49 pm »
Fantastic post mrhighcalober. Very informative.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #7249 on: November 05, 2019, 04:57:26 pm »
Sent some logs out to Brad last night, from my logs it looks like I have a few degrees he could add to my spark advance.
Anybody know what the reply time with brad is like nowadays? I've heard hes gotten busy with IRL stuff.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #7250 on: November 05, 2019, 04:59:57 pm »
When mine went bye bye, it was instant and from a dig.
first thing I did when I got the car was 2 flushes with amsoil 75w-140.
Thanks for the insight on PTU failures.
As for protecting the PTU from heat, any recommendation on what I should wrap my DP's with to try to keep it isolated?
« Last Edit: November 05, 2019, 05:05:23 pm by Gofspar »
Offline SM105K
  • Forum Supporters
  • Arizona
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
« Reply #7251 on: November 05, 2019, 10:28:59 pm »
I wrapped mine in typical exhaust/header wrap. 50 feet for like 12 bucks. You live in AZ too, your DP's wont rust if you wrap them.
« Last Edit: November 05, 2019, 10:32:54 pm by SM105K »
Offline Gjkrisa
  • Fairbanks, AK
  • -Given: 974
  • -Received: 217
    • Photos
« Reply #7252 on: November 05, 2019, 11:08:42 pm »
Professionally detailed, single stage color correction, high speed buff detailed, etc...
Not too shabby...
TLC Automotive Detailing in Sterling, VA. Dave is the owner of the shop, just good dude.
What that cost you?
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #7253 on: November 08, 2019, 03:02:15 pm »
I ordered a new set of 3D Maxpider Kagu Floor Liners part number and link
For reference below.
The last set of Aries Liners served me quite well since purchasing them back in 2016 which were later replaced by the newer updated version 3D Maxpider Liners. Z
[L1FR01801509]
https://www.autoaccessoriesgarage.com/Floor-Mats-Liners/3D-Maxpider-Kagu-Floor-Liners/_Item/_556100636
« Last Edit: November 08, 2019, 03:54:18 pm by ZSHO »
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #7254 on: November 08, 2019, 06:43:35 pm »
You will love the Maxpiders.
Offline StealBlueSHO
  • Administrator
  • -Given: 2524
  • -Received: 2579
« Reply #7255 on: November 10, 2019, 04:14:22 pm »
Just quick video with some thanks that I put together!
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
« Reply #7256 on: November 10, 2019, 06:07:35 pm »
Fixed the radiator leak. Turned out to just be a loose clamp and got an oil return line on the way as I think mine is leaking off the rear turbo and not the gasket I've replaced twice. After second replacement the oil leak got significantly worse RIGHT after the fix and only other part I touched was the line itself so I think it's leaking from the flex or maybe from the flange. Hard to tell as the leak goes onto the axle and it flings it everywhere. All I know is that it the only piece I've touched so car has that part out right now and waiting on replacement to arrive Tuesday.
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
« Reply #7257 on: November 17, 2019, 05:23:42 pm »
Well, car is broke again. Flashing CEL, running on 5 cylinders, new plugs and swapped coils. Number 6 still giving issues. Fuel pressure funky at idle car hasn't been ran much. Number 6 covered in fuel. Diagnosis says #6 injector stuck open.
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
« Reply #7258 on: November 17, 2019, 05:33:18 pm »
So yesterday tore the car apart, intake and charge pipes removed, radiator drain. Basically just need to take off coolant hoses and intake manifold. Replace injector and intake manifold gaskets and reassemble then oil change just in case from fuel dilution. Better safe than sorry on that.
Offline 802SHO
  • Essex Junction Vermont
  • -Given: 2068
  • -Received: 993
  • Boosted
« Reply #7259 on: November 17, 2019, 08:39:51 pm »
Fingers crossed you caught it just in time!  Might as well replace them all.....upgrade time?
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
* Featured Topics
* Recent Topics
Re: Transfer case torque limit
by FoMoCoSHO | Today at 09:44:56 pm
Who is your tuner?...
Re: MrHighCALiber's SHO Forged Engine Build
by StealBlueSho | Today at 08:50:30 pm
Cylinder 2 had some issues. 0psi compression was the main one. Lolhttp...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | Today at 04:40:16 pm
Hptuners most likely supports this. Email and ask them. If not they ca...
Re: EBPF Under New Ownership!
by 76fomoco | Today at 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | Today at 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | Today at 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
by 802SHO | Today at 05:27:29 am
Man that flywheel ssssure issss perrrtyyy Sent from my LM-G710VM using...
Re: 802SHO 2010 Build
by 802SHO | Today at 05:19:39 am
I would be super intrigued on the 13+ manifolds and how they work out....
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: MRT blues
by FoMoCoSHO | May 24, 2020, 10:17:35 pm
https://www.ecoboostperformanceforum.com/index.php?topic=9807.0Well, a...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Re: Performance Oil Pan
by bpd1151 | May 24, 2020, 06:08:01 pm
Hey Everybody. Thanks so much for all of the comments and ideas. After...
by StealBlueSho | May 24, 2020, 05:44:23 pm
Just a quick clean with my favorite detailing product!https://uploads....
Re: 2013 MKS w/57k
by MKS Tom | May 24, 2020, 04:23:36 pm
You really will enjoy it.  It is a lot of car for the money. ...
Re: What size filter sock/cover for EPP gen 2 dual filter?
by StealBlueSho | May 24, 2020, 03:50:19 pm
I used Part Number: 20-1770 for my original version Gen 1 intake and f...
Back to top
