Quote from: SHOdded on June 05, 2019, 06:43:32 PM
Since the cooling is relative, if the temperature drop is about 40 degrees from ambient on both center vents, the system is deemed to be working properly.
So on a hundred degree day, you can expect 60 degree air max.
Thanks my friend. Z  :)
Macgyver
FiveLeeter918
Took second place in the SHO class for the 2019 Eureka Springs Mustangs Days Saturday :)
did a full detail, installed my Ethanol Content Analyzer (which seems to be dead :-/), installed EPP hot pipes, and my Flex underbelly cover.
Yesterday I went ahead and installed my new XDI-35 fuel pump and started tuning it. Ready to see what she can do.
- Lee
Gjkrisa
Installed new shoes
Michelin pilot sport 3+ 99v
ecoboostsho
Swapped out the Primary Oxygen sensors as I was inspired by a both 802SHO and SBS and probably a few others...it went much better then I expected because being driven through several MN winters I was expecting the worst but both sensors came right out with just a little penetrating oil.  I did use a crows foot (Tekton) oxygen sensor wrench which worked out awesome.  Also used the aforementioned "shoe lace trick" on the rear which made reconnecting the harness a LOT easier.  I do have one "tip" to add though - if you are using the crows feet on the front sensor (from under the car) and you have a performance pack oil cooler (at least I think that is what it was) be careful not to overrotate the crows foot when you are retightening the O2 sensor because the ratchet gets "stuck" behind the oil cooler.  I spent a lot of time trying to wriggle and pry and maneuver it until I finally found just the perfect combination that let me back off the wrench.  The obvious fix would have been to just reverse the ratcheting mechanism but I couldn't because the wrench had enough pressure on it.  I was envisioning either driving it red faced to a mechanic with a wrench attached or worse.  Anyway hopefully that will save someone else the same issue.  Here's a shout out to everyone who did this before me that made it a lot easier!!!
802SHO
Quote from: ecoboostsho on June 09, 2019, 05:36:18 PM
Awesome glad it went well all things considered!  I had to free my wrench on both 02s after loosening...i think bc of the surface rust on them.
@ -ecoboostsho your SHO will be much happier now with the new 02's Z  :)
jims2015
I got to use my quickjack for the first time to change the oil. I didn't use the highest setting or I could almost sit up under there. I was hoping this will finally keep me from spilling some oil on the floor like I do when using jack stands. So easy, I could reach straight out holding the drain pan close to the engine with both hands. Then a giant fkn mosquito lands on my arm and starts drilling. I try blowing it away but no go. So I took away one hand from the pan for a quick swat and..... you guessed it. I splashed more oil than ever on my floor.
2015 PP, Thunderstorm DP & CAI. AlkyControl, Livernois dyno tune
2019 Corvette C7 Z51 A8 No mods
Black Dream
Just waiting on the mailman to bring me the SCT X4 and new plugs I ordered so I can start tuning my new-to-me beast.  I went with Unleashed for the tunes and I bought the SCT used from them with pre-loaded and 2 MKS custom tunes already installed.  I had the chance to add 3 custom tunes of my choice affordably as well so I did, any suggestions you all might have for what tunes to look into?  Of course I'll have to see what the 2 custom tunes are already loaded and go from there.  Leslie over at Unleashed has been a godsend so far, his customer service has been outstanding...
2010 MKS Eco, Airaid, SCT X4, Unleashed, SP542 plugs, 3 bar MAP and current daily.
2006 Pontiac GTO M6, 1 of 101 exactly like her, bone stock, lost to flood 5/19, gone but not forgotten....
Macgyver
Quote from: Black Dream on June 10, 2019, 12:45:02 PM
E30 tune if you have E85 etc around.
shoNoff
When will e85 come to nh? When? God we are so far behind. At least I know I'll get it before 802sho. I bet Vermont won't get that until 2030
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
802SHO
Quote from: shoNoff on June 11, 2019, 07:44:58 PM
Damn I hope I am still alive by then jeez...wait that's only 11 years....i better still be kicking it lol
Gjkrisa
Quote from: 802SHO on June 11, 2019, 08:45:50 PM
Wow in 11 years gas card you drive yourself could be outlawed unless it for racing
802SHO
Quote from: Gjkrisa on June 12, 2019, 12:41:41 AM
That's true...and one heck of a scary thought!
