802SHO
Quote from: StealBlueSho on December 05, 2018, 08:42:14 PM
Ordered a Corsa exhaust with the silver tips... $945 shipped new...I could not say no.
That's a great deal!  Smart choice!
BoostfoSHO
Installed these transmission mounts, it's a night a day difference on the launch. Car takes off like it's in rails. Got rid of all the wheel hop and the 1st to 2nd shift is so smooth. Totally worth the money.
Sent from my SM-N960U using Tapatalk
AJPTurbo FTW
2015 SHO PP
Air raid intake, 3bar, OBX catless downpipes, 160tstat 2. Electric exhaust cutouts, MSD ignition coil, hot pipes with Tial BOV, AJP Turbo wastegate regulator mod.
For now...
Pending install. Snow stage
ToMang07
~Tom~
2013 SHO - Stage 3 Snow Performance Meth, (2) SCT X4 with Unleashed, 3 Bar Map, MSD Ignition Coils w/Colder Plugs 170*TS, EcoPowerParts Hot Pipes & Tial-Q BOV) Stage 3 Motorsports Catless Downpipes 3" Cat-Back Exhaust, JLT Oil Separator, H&R Sport Springs, K&N CAI, Drilled and Slotted Rotors w/EBC Pads
BoostfoSHO
Quote from: ToMang07 on December 06, 2018, 10:50:09 AM
DIY job?
Where'd you get them? How much?
The guy is on FB, idk if he frequents this forums and if he does I wouldn't know the username but here's a screen shot so you can find him on FB. $200 shipped.
AJPTurbo FTW
2015 SHO PP
For now...
BoostfoSHO
For those without Facebook his email is tonyuep@aol.com
AJPTurbo FTW
2015 SHO PP
For now...
shaundizzle15
Hockey/Golf/Car geek, Beagle loving, and totally comfortable with it.
Tuxedo Black nonPP 2013 SHO traded in
Shadow Black nonPP 2016 SHO
VTA, and tuned by GH
BoostfoSHO
AJPTurbo FTW
2015 SHO PP
For now...
Macgyver
Thats a great price for them. Well worth it.
I was going to do the poured in Urethane method/mod on the OEM. Just never got around to it.
StealBlueSho
New parts! Yay!!
802SHO
Quote from: StealBlueSho on December 07, 2018, 07:28:50 PM
New parts! Yay!!
That was quick.  Stop working out with bands and install that bad chicken lol
StealBlueSho
Quote from: 802SHO on December 07, 2018, 09:42:57 PM
New parts! Yay!!
Ha! It's my wife stuff... she's a personal trainer... yes she has a 6 pack.. no I do not...
That box is getting wrapped up and put under the tree... so I won't be getting around to it until probably after the 1st of the year.
Jordan
Got mine in yesterday and installed em today in my garage. Pretty straight forward install. Definitely can launch a bit harder now. Absolutely excited to see what the car can do now. 1-2 shift is just so nonchalant now. The car just seems so tame instead of violent now. Noticeable NVH while cruising, but it's absolutely not bad.
nickstewartroc
Quote from: Jordan on December 08, 2018, 10:21:59 PM
Did you have to adjust the left one at all? Not really seeing why it would be designed like that if not
Current:
Jordan
Quote from: nickstewartroc on December 08, 2018, 10:36:50 PM
Just slightly to line up the holes. I am curious if you could tighten it up to increase tension on the trans would be my only reason for it to be adjustable, but I just got it to fit then locked it down.
Jordan
Update on the mounts.
Pros: Can launch at higher rpms with no issue. 1-2 shift has total traction now. Shifts are crisp and without issue.
Cons: Slightly more vibration around and under 2k. Slight vibration while cruising.
Overall: Absolutely an improvement and is still dailyable... Going to have to get brad to up my shifts now! Ha! The stock mounts are absolutely abysmal and you can move the mount pretty easily just by hand. Wonder what it looked like with 500ft lbs on them. Crazy.
