Quote from: SHOdded on April 21, 2018, 07:26:51 PMA KAM reset should be sufficient to get the new TPS recalibrated.FoMoCo, did something let go on the MKS?
Quote from: jonnoriega on April 25, 2018, 01:35:52 AMHaven't posted in a while. Added a Borla S-Type Cat-Exhaust and PowerStop Z23 Brake Kit. As for the appearance, I got it re-wrapped thanks for Crown Customs & Coatings in Elk Grove, IL. Next phase will be re-coating my Velgen VMB6 wheels.
Quote from: lamrith on April 25, 2018, 11:18:04 AMQuote from: jonnoriega on April 25, 2018, 01:35:52 AMHaven't posted in a while. Added a Borla S-Type Cat-Exhaust and PowerStop Z23 Brake Kit. As for the appearance, I got it re-wrapped thanks for Crown Customs & Coatings in Elk Grove, IL. Next phase will be re-coating my Velgen VMB6 wheels.Awesome looking rig! What tires/wheels sizes are you running?
Quote from: jonnoriega on April 25, 2018, 11:30:08 AMQuote from: lamrith on April 25, 2018, 11:18:04 AMQuote from: jonnoriega on April 25, 2018, 01:35:52 AMHaven't posted in a while. Added a Borla S-Type Cat-Exhaust and PowerStop Z23 Brake Kit. As for the appearance, I got it re-wrapped thanks for Crown Customs & Coatings in Elk Grove, IL. Next phase will be re-coating my Velgen VMB6 wheels.Awesome looking rig! What tires/wheels sizes are you running?Thank you!Velgen VMB 6 WheelsTires are Parada SpecX 295 45/R20 with 45mm off set
Quote from: SHOdded on April 27, 2018, 04:27:54 PMoooooo ... well, the wrap's off this project then! What is the flow gain again, 40%? The graph only shows the Severe Firestorm, I think.https://www.livernoismotorsports.com/shop?keyword=firestorm+hpfp
