- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: Jordan on November 17, 2019, 05:33:18 PM
So yesterday tore the car apart, intake and charge pipes removed, radiator drain. Basically just need to take off coolant hoses and intake manifold. Replace injector and intake manifold gaskets and reassemble then oil change just in case from fuel dilution. Better safe than sorry on that.
Fingers crossed you caught it just in time! Might as well replace them all.....upgrade time?
