Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
Nova
Quote from: Quinid on September 27, 2019, 05:15:28 PM
Nova, the same exact thing happened on my Flex. Came off on the freeway and flapped around beating up my paint as I try to get to a stop. My double sided tape looked the same.  I don't know what your warranty situation is. If they tell you that it does not cover trim, remind them that the security pad is on it and those two can only be ordered as one piece. The Ford extended warranty covers the security system so they must cover it. It worked for me.
This morning I tapped the trim piece to the car so I didn't cause any damage to my paint. While going down the freeway I heard something and couldn't see it hanging off so I couldn't figure out what it was and when I got to the dealership this is what I saw...
I'm still under warranty so they ordered the part and will be there Monday morning.
Sent from my SM-G965U using Tapatalk
StealBlueSho
Haven't been around lately.. work, moving, etc... but finally had a chance to pull the SHO out, get it cleaned, and snap a couple pictures... MAYBE get to the track in the next couple weeks before the tracks close... all the kinks in the tune are worked out now so no more 50% throttle going down the track which did net me a 12.1 last time.. so should be a solid in the 11's...
Macgyver
Quote from: Nova on September 27, 2019, 05:47:28 PM
I cannot beleive Ford and other mfgrs use this crap. My Passenger side is starting to come off.
I am getting a roll of this stuff.
https://youtu.be/cIasko9-AmQ
I think quality has taken a hit over the last decade or more since the downturn.
No emblems faded, no chrome peeling, no appliques falling off, no rust on my 2007 Edge.
802SHO
Quote from: StealBlueSHO on September 27, 2019, 05:54:00 PM
Idk....looks like photos taken in order to sell the poor girl off.
I hope you do go back to the track!  You're going to be happy if you do!!!!!!!!
Jordan
Teaser for y'all last night. Left lane
I guess I shouldn't say teaser because that was my best last night but 4k da
StinkinLinkin13
Nice! How is your launch? RPMs? I just started running full E85 and Meth injection and traction is pathetic even with my 275s DWS06 on 10 inch wheels  all around. I haven't gone to the track again yet so just looking for advice before I do. My biggest disappointment thus far has been this AWD RDU clutch setup... I wish we had all time awd like Subarus and Evos...
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Jordan
Normally launch at 2k and hook great. Tried a little higher while also getting more aggressive with the baby shot and it didn't pan out in my favor and ended in an 11.19
802SHO
Quote from: Jordan on September 28, 2019, 04:13:58 PM
Damn...only an 11.19?  That sucks!
Is it just me or isnt that still amazing!!!????
Jordan
Quote from: 802SHO on September 28, 2019, 04:52:06 PM
Lol, I guess I shouldn't act spoiled about it. It was more of a in every aspect the run should had been better, but wasn't so on that side of things I am bummed about that run. It felt amazing and I was expecting closer to a 10/possibly a 10 haha.
StealBlueSho
Run enough nitrous through anything and it can be fast... for a bit :-)
Congrats!
Gofspar
Quote from: Nova on September 26, 2019, 07:23:17 PM
Called the dealership to set up an appointment because this side trim piece came off and was hanging by the wires while I was driving down the freeway.
same s*** happened to me doing a pull from 70-xxx, ended up using 3m double stick to position it and JB weld plastic bonder.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
TopherSho
Quote from: Gofspar on September 28, 2019, 07:37:32 PM
JB weld after alcohol scrubbing the contact points.... on three different panels.
Best 0-60 public road 4.35s
Nova
After getting home from the dealership I get out of the car and see this...
