Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
802SHO
Quote from: Macgyver on September 01, 2019, 11:41:58 PM
My son has had a couple of 600CC sport bikes. Aprilia 660. Honda CBR600. Yamaha YZF-R1.
No way I can keep up with him untuned or tuned.
I've owned an 01 GSXR 750, 04 GSXR 600 and an 06 Yamaha R1, I did not expect to win against that bike on the interstate.  I don't know what kind of Bike it was, its possible it was some sort of 600, definetly a low 12 second bike whatever it was.  Just cool to beat!
Macgyver
Oh for sure.
To me they all look the same so no way of knowing what they are speed wise.
Usually you see that single tail lite walk away from you.
Sent from my LM-G710 using Tapatalk
802SHO
Quote from: Macgyver on September 02, 2019, 12:15:56 PM
Oh for sure.
I got lucky lol!  Perfect timing though, right after setting a PB time.  I was elated haha
Macgyver
Did you see the Juke up there? A guy I know was up there and only got one run in.
Moisme33
Today I.... Traded in my 2011 SHO for a 2015 non-performance package SHO! I will post pics tomorrow since it was dark when I left the dealership here in Ohio. First thing I will say I noticed is that there is definitely a big difference in the suspension coming from H&R springs on my 2011, now I just float down the road here in the 2015 haha. Also, I am a bit old fashioned in the sense that I liked the dials on the 2011 system's center counsel, the new touch buttons on the center counsel in the 2015 will just take some getting used to. Other than that it is great!
GhostlyGrenade
Quote from: Moisme33 on September 02, 2019, 09:44:09 PM
Nice!!
2015 SHO Darkside paint color, 3 bar, Motorcraft SP542 plugs@0.28, MSD Coils, K&N drop in, Continental Extreme Contact tires 255/45R20, EBC Yellow pads, 170 T-Stat, Redline 5w30, updated to the 2018+ trans mount, E-30 Blend, TUNED by AJPTurbo
802SHO
Quote from: Macgyver on September 02, 2019, 04:52:49 PM
I didn't see him, I probably would have if I knew what to look for.
bamsho
As some of you know already, but after 6 years with Livernois, I have moved on and changed tuning vendors, after installing the new actuators and intercooler, I saw no improvement and the V10 tune didn't adapt.  I went to Gearhead Tuning.  I feel with what my current goals are, I think they are the ones to get me there.  Loaded my intial tune file yesterday, and was VERY impressed.  Ive run my V10 tune enough, that it is my new normal, so I can honestly tell you, def a difference to the good.  They fixed an issue I had ever since installing Turbosmart actuators and GH intercooler.  I was asked to send a log after talking with Matt since I'm running the better actuators.  So I close one chapter, and open another.
Quote from: bamsho on September 04, 2019, 06:04:55 AMAs some of you know already, but after 6 years with Livernois, I have moved on and changed tuning vendors, So I close one chapter, and open another.
Seems to be a growing trend.
Continued successes moving forward!
Gray Brick
Started to pull apart engine to repair blown head gasket.
While I am in there... chains, water pump, phasers, etc.
160k miles and plan to get another 100k out of the motor.
2013 Ecoboost Ford Flex
You can see the updated timing set in there.  Will be interesting to measure the stretch vs new.
nickstewartroc
Quote from: Gray Brick on September 04, 2019, 11:10:27 AM
I'll be doing my Flex soon too, only at 78k, but a little rattle at start and had the cam code thrown a while back. Rather do it now than have something happen
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
Hotrod Lincoln
2011 MKS 81K Miles
