Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
Gofspar
#6915
MSD coils are in, cold start and my idle is so much better with them. (also the red looks kinda neat.)
Ordered a set of EBC Redstuff for front and rear and some RBF-600 but of course USPS f'd up and lost the fluid for two days so it'll come in on Monday, so guess I stare these EBC boxes until next weekend.
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
TopherSho
I just did this today as well!  Seems to have added **A LOT** of smoothness at idle and seems to have eliminated the 'stuttering feeling' when you accelerate in OD 'juts slightly'.  Seems snappier..
Best 0-60 public road 4.35s
DaveBey
With the help of my brother, I installed the Eco Power Parts hot pipes and Eco Power Parts intake into my 2010 Lincoln MKT on Saturday. The clearance for the intake pipe to the rear turbocharger was tight; we had to massage the rear air conditioner tubes bit to be comfortable. We did not have bolt handy to fit the bolt hole in the end of the S&B air filter so we tapped the hole and used a bolt with some Teflon tape. I need to check the pressure side as I think I may have a small boost leak. I hear a higher-pitched 'whistle' sound leading up to the bypass valves opening. I ordered my pipes with the crinkle black coating and it looks very nice.
2010 Lincoln MKT AWD | Gearhead intercooler | Gearhead tuning | PPE Engineering downpipes | Eco Power Parts hot pipes | Eco Power Parts intake | Motorcraft SP542 spark plugs at .026 | Motorcraft CX2594 MAP sensor | UPR Dual Valve Catch Can with Clean Side Separator | 2013+ Motorcraft heavy-duty brakes | Goodridge G-Stop Brakeline Kit | 2013+ Ford auxiliary transmission cooler
802SHO
Didn't get much alone time with the SHO this weekend but my Zex Safe Shot kit is near complete.  Just need to run the no2 line from the trunk, using the frame as conduit, up into the engine bay.  Then maybe get fancy and bend some abs plastic to use to mount the arming switch and activation button.  But just to test it I don't need to go that far.  Can't wait.
mrhighcaliber
Quote from: shoNoff on August 16, 2019, 04:43:03 PM
Just be careful guys. This is exactly how people start with nitrous. Then all the sudden it's rods hanging out and people yelling nitrous sucks.
F me I just showed my age lol
Give em the ole' "you'll put your eye out!" Scolding.
Sent from my PH-1 using Tapatalk
Jordan
Quote from: 802SHO on August 19, 2019, 06:46:03 AM
Keep me posted lol. I think I'm going to try pre turbo spraying
802SHO
I ran the line from the trunk to the engine bay last night.  It was sort of a pain.  That's done, just need to secure the bottle(drill into the trunk) and simply connect my toggle switch and I can check the lines for leaks, then let her rip tonight after work.
76fomoco
did the kit come with the relief valve and line vent to outside the trunk to pass tech inspection?
2013 PP AJP E30 160 TS, sp542 plugs, 3 bar, PPE catted DP's, GH IC, GH turbos, XDI-35, EPP hot and intake
Best 3-29-21  11.85 with 3000 DA
DA trap best 117.96
E30 = 492 whp, 536 wtq
E30+meth 498 whp, 539 wtq
802SHO
Quote from: 76fomoco on August 20, 2019, 09:20:49 AM
I'm not 100% certain I know what you mean.  Like a purge kit?  To test the lines for leaks I'll open the bottle and look for frost while the engine is running.  If I don't see any frost I should be good to go, then I'm to close the bottle and bc I don't have a purge kit I will need to loosen the line to either the bottle or the solenoid I believe.
Do you mean tech inspection at the track?  In that case I don't know....ive never done this before.  If you mean regular state inspection I'm not concerned with that.
802SHO
Anyone know what this knob is on the back of the bottle?  Is this a relief valve?
76fomoco
DA trap best 117.96
802SHO
Hmmm...definitely sounds like a safety feature for some crazy nitrous setup.  This is just a 15 dry shot.  Certainly don't need any safety features to that extreme.  But at the local track...now I will be one mad son of a .....if this turns into an issue.  Not sure if the rules are less strict on a street night with just test and tune.  Unfortunately the nitrous solenoid and nozzle are extremely visible under my hood
Jordan
Quote from: 802SHO on August 20, 2019, 10:28:22 AM
You weren't even going to purge were you?
802SHO
Quote from: Jordan on August 20, 2019, 10:31:06 AM
No bc it's not needed for the small shots.  That's what I asked Zex about.  He said you need purge kits when you're using a wet kit and a much bigger shot...he said with the small dry shots especially a 15 it's not necessary bc it doesn't need hardly any pressure for that and no need for a bottle heater.
802SHO
Eventually I wanted to purge bc it looks cool lol
