Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
802SHO
#6630
Quote from: ZSHO on July 11, 2019, 06:49:16 PM
Here are a couple PICS of the MOTORCRAFT DY1185- 8F9Z9F472H Front wide-band 02 sensors @ roughly 7K on them for reference! Z
I would expect them to look better than that after only 7k.
Most recent thread below on 02 Sensors
https://www.ecoboostperformanceforum.com/index.php/topic,299.msg144236/topicseen.html#msg144236
[PART NUMBERS BELOW]
https://www.ecoboostperformanceforum.com/index.php/topic,8974.0.html
Look worse than id imagine at 7k.
Jordan
Weight reduction has begun again. Slowly but surely. Currently have back seats out. Getting ready for the 19th drag strip trip fifteen minutes at a time lol
Chris_Flex
Mounted my new tires and wheels on the Flex I think it turned out awesome! The way I can throw this tank around corners with the Falken Azenies fk510 tires I love it and the stance alone is mean looking I think now I need some coilovers.
The rears are actually only 3.5lbs heavier compared to stock
F- 20x9 270 40
R- 20x10 315 35
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
802SHO
Got Inspected today.  Between the mileage on my last sticker from May 2018 to now July 2019 I put a whopping 3,200 miles on my car.  That's pitiful.  I hit 73k on the odometer on the way to get her inspected.  I also got my Sync home screen looking much better with my Tuners Avatar.
SM105K
802SHO
lamrith
Quote from: 802SHO on July 17, 2019, 01:02:32 PM
Nice, where did you get the larger graphic of his logo?  Or did you blow up the avatar he uses?
802SHO
I found that symbol on Google searching turbo shooting flame and then added the text.
Jordan
Car is stripped out. Full weight 4180 -> Stripped weight 3960 and probably found another 20lbs since last night. Going to the drag strip friday and taking of the exhaust at the strip. Pushing for my best possible. Attempting an 11.51, but it'll be hot and it'll be close... Who knows! Just an attempt!
802SHO
220 sounds easy but I bet its not easy to get that much out.  Good luck!  What is the suggested temp and DA for Friday?
802SHO
I'm going to try next Friday, possibly Saturday.  Can't see weather for Saturday but next Friday it will be 75 degrees at 8pm.  Not sure about DA but 2700 DA is about as high as it gets.
Jordan
Quote from: 802SHO on July 17, 2019, 03:27:08 PM
It's going to be rough. 97 degrees and absolutely 4500da probably. Temps going to be fighting me
802SHO
Quote from: Jordan on July 17, 2019, 04:18:36 PM
Where do you weigh your car?  Some sort of weigh station?
6500rpm
Quote from: Jordan on July 17, 2019, 03:07:42 PM
If you get the win and the time, you're going to need to learn how to do a back flip just like another Ford driver from Columbia MO. (  ;
2013 SHO PP in Ruby Red Metallic, GTG Billet Grills, Duraflex Racer Chin Spoiler, DriveBright LED Driving/Turn Lights,160 T Stat, MSD Coils, All Royal Purple Lubricants, EPP Gen 2 Duel Intake and hotpipes,3 bar, Gearhead AO tuned!
