Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
802SHO
I got this one from Griots garage.  I've don't a lot of wetsanding and fixing orange peel and clear coat runs when I used to do detailing and tinting full time.  When done correctly wetsanding just skips a lot of fussing.  For tiny light surface scratching yes a good compound with one to several applications does the job!  But 2 and 3000 grit wetsanding...is really light....but will just make the paint so clear its sometimes worth going that far.  For removing a real scratch I'll go as low as 1,000 grit...not usually less than that...definitely not on factory paint...very thin clear coat.
https://www.amazon.com/Griots-Garage-10813STDCRD-Orbital-Polisher/dp/B009UKUUWE
SM105K
Quote from: 802SHO on June 25, 2019, 02:05:21 PM
There you go.  Boom!  Good stuff. I burned through my clear and base on my rear quarter on a beveled edge.  I was wet sanding with my small air polisher and got too aggressive.  You have to look for it, but I know it is there, and it reminds me to not be over aggressive. I refuse to fix it because of the lesson it taught me.
SM105K
Also, I ordered the Gen2 mounts from Tony.  I emailed him and he responded very quickly.  Items were paid for, and I already have a tracking number. Pretty damn quick if you ask me.  I am excited to see what these do for my SHO.
802SHO
For a "middle man" he pretty much runs the SHO lol!  They are great!  I enjoy the feel of them.  You feel everything...even the tiny engine turnovers as it starts.  I love it!
And don't let me fool ya, I've been too aggressive as well wet sanding.  The edges I learned to stay away from!
SM105K
I am actually going to try the Meguiars Mircofiber compound and polish.  Just to see what happens.
SM105K
I pulled the chrome trim off tonight. Only cut myself once, so that is W in my book. Trim is ready for paint.
Not going to lie, I was annoyed when I had to pull apart the from clip for the grill.
802SHO
Quote from: SM105K on June 26, 2019, 09:08:43 AM
Window trim come off pretty easy?
SM105K
Quote from: 802SHO on June 26, 2019, 09:15:21 AM
No...I was rather impressed with how well it was adhered. I only drew blood once, and thought I only cut myself once too.  I was wrong when I got in the shower lol.
All in all it wasn't bad and took me about an hour and a half. Since the trim is off, I am going to wash, clean, and do a full paint correction.  I need to go to Ford and buy some new clips.
802SHO
Great project man and a good idea!  So the trim is has a bunch of retaining clips...and some sticky tape?
SM105K
#6564
Quote from: 802SHO on June 26, 2019, 09:25:36 AM
Yeah.  The window trim was the worst.  The top two pieces over the window have retainers on the end that are removable.  Just pull the weather stripping and you will see.  Then I just used a two large screw drivers and gently pried them off.  The bottoms are hooked so be careful when completely removing them.  Be careful not to crease them. The bottom pieces are held as a unit with clips.  I could not, not break the end clips because I would have to take the inside door panel off.  I was not willing to do that.  So I will replace them.
The two accent pieces near the back door, are held by one clip and two inserts.  Pry up on the front, clear the inserts and push the whole unit forward.  One of mine broke, so the base will be replaced.
The trunk was pretty easy, remove back up camera, and two 12 mm nuts.  I then used a rubber mallet to smack the retainers.  It came off pretty easy.
The grill...you have to at least get it to sag like I did.
The credit card trick on the SHO side badges was money.  Thank you for dropping that gem.
802SHO
Good info man thank you for that!  Once I get my car fricken on the road first lol then I'll next clean her all up and take the trim off like you did.  Will probably get it painted but I may dip it. Dip maybe bc it's so cheap and lasts for a long time when done right.  Although paint would be one and done.  Are you going to color match it or just go gloss black?
SM105K
#6566
It is getting completely paint matched in tuxedo black.  I like how that looks.  With the rims, and quad tips, it should look like a completely different car. I am just trying to figure out if I want to do any accent work....
I think black and copper/bronze would be pretty cool. Maybe copper/bronze calipers and turbo bull overlays?  Just very subtle.
802SHO
#6567
Quote from: SM105K on June 26, 2019, 12:51:26 PM
I think black and copper would be pretty cool. Maybe copper calipers and turbo bull overlays?  Just very subtle.
That will look nice color matched trim!  I just had my front spoiler repainted and that expensive Billet Badge painted to tuxedo black to match bc I didn't like the carbon black.  Picking them up tonight.
Its funny you say copper!  I've had some copper plasti dip sitting in my garage for over 2 years untouched.  Originally I was going to spray my wheels that color but then decided to do black.  But recently I thought about it again.  I was kicking the idea to spray over the black plasti dip and glossifier with the copper.  Although that wouldn't be subtle.  Then I don't think I would want my calipers red anymore.
The copper calipers would look good I think.
SM105K
I sent a custom order request to Devires to see what they could do.  I want more like a burnt copper/bronze.  If they can do that, I will buy the set from them for my front and rear Ford emblems.  If I like the color and I just get it paint matched for the calipers, then have them done.
glock-coma did the wheels on his 2010 in copper IIRC.
