Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
SM105K
#6465
Dropped a W on another SHO on Saturday. Then I took two L's yesterday to a Fiesta ST in my Focus ST.  I posted both stories in the racing tall tales, and lessons learned thread.
Gray Brick
Make sure to check your Air Duct Valves...
My waste-gate duty cycle started going up so i found this on a pressure test.
2013 Ecoboost Ford Flex
SM105K
Quote from: Gray Brick on June 03, 2019, 02:40:24 PM
I know what I am doing when I get home.
shoNoff
Quote from: SM105K on June 03, 2019, 03:03:23 PM
Me to and it involves drinking and watching my Bruins! Bring me that damn cup Boston!
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
shoNoff
Wow thanks I'll have to take a look this weekend.
True Indeed! But the very reason i went with the Hotpipes & TIAL -10psi- BOV . Z
SM105K
Quote from: ZSHO on June 03, 2019, 05:25:48 PM
True Indeed! But the very reason i went with the Hotpipes & TIAL -10 BOV . Z
Looks sharp Z.
Thanks there E!  :) I spend to much time on the SHO & NO wonder the wife hates me! Lol. Z
shoNoff
I think I see a spec of dirt to the right of the hpfp. Just saying  ;)
Vvvdannyvvv
#6474
finished a week ago, but figured id share it here....
3m, Matte blue, turned out better than i thought.
2012 SHO
Plugs, 3 bar, Catless dp, springs
Fastest Run stock 13.9 full weight plus extra
Fastest run on LMS 93 Race tune 12.41 full weight.
Fastest run on Ortiz TBD
802SHO
Quote from: Vvvdannyvvv on June 04, 2019, 06:54:43 PM
That's sick!
Jordan
Looks good you have any help doing that? lol
I orderd a Water Repellent (Pre-Filter) In Black for new Dual intake!
$28.95 with Free shipping included. Z  :)
https://www.outerwears.com/proddetail.asp?prod=7237
Today calibrated the Supco ST01 Pocket Dial Thermometer and did not have sufficient time to fully experiment with this little handy gadget but did install it on the (Drivers side) vent with MAX A/C ON & Blower Speed set to 1.
The correct method and Desired Fan speed should be set @ 3 or 4 with MAX A/C ON and the average Temps should hover roughly around 36-46 ON the DIAL Through the (Center vents) with a strong charged A/C System.
I did see close to 40 deg on the Dial and will try to post any updates soon. Z  :)
Since the cooling is relative, if the temperature drop is about 40 degrees from ambient on both center vents, the system is deemed to be working properly.
So on a hundred degree day, you can expect 60 degree air max.
