Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
SM105K
#6105
Quote from: StealBlueSho on February 21, 2019, 03:06:43 PM
I have had no problems holding more than 15psi at redline with my GH tune after the IC install...
With my GH tune I hold 17ish psi and it drops to 15ish at redline...
With my LMS tune I hold 15psi and drop to about 14psi at redline..
All post IC install.
It holds 15ish at redline even after the GH IC install.  Maybe the IC is too big to keep the boost up on these little turbos.  I know Matt had talked in a thread that upgraded turbos would really benefit from the GH IC.  He also said the IC is on the verge of being too big for the stock turbos. So who knows.  Maybe my turbos are tired.
If Brad sees this maybe he will chime in.
StealBlueSho
Quote from: sm105k on February 21, 2019, 04:27:10 PM
It holds 15ish at redline even after the GH IC install.  Maybe the IC too big to keep the boost up on these little turbos.  I know Matt had talked in a thread that upgraded turbos would really benefit from the GH IC.
Maybe, Matt says the IC is 20% greater in volume. That being said... I just looked at a guys datalog with stock turbos and GH IC holding almost 19psi to redline with 20+ degrees of spark...
SM105K
Quote from: StealBlueSho on February 21, 2019, 04:30:27 PM
Either way, my SHO is riding and I am extremely happy.  It should show on the dyno tomorrow at 9 am in 40 degree air.
You have good turbos..I remember running 20 psi no problem in my sho
StealBlueSho
Quote from: AJP turbo on February 21, 2019, 05:20:45 PM
Hope so, car only has 17K miles on it... besides these stockers won't be on long... ;-)
Jordan
I know I mentioned it, but I never posted anything. So now when I beat people in races I say you got beat by a pile of ship.... Or I yell ALL ABOARD when people going to ride in the taurus.
SM105K
Jordan
Quote from: sm105k on February 22, 2019, 07:15:25 AM
Guess I am doing springs tomorrow.
Nice! Just a suggestion but put a couple hundred pounds in the back when you finish. Helps get the rear settled in
802SHO
Do what I did, just get in the trunk and bounce the living scrap out of it...same thing ...sort of.
SM105K
Quote from: 802SHO on February 22, 2019, 11:11:53 AM
Quote from: Jordan on February 22, 2019, 10:54:54 AM
I am just going to drive the piss out of it.
SM105K
#6115
I installed my H&R Drop springs this weekend.  That was fun. Couple of take aways.  I have a 13 so the front is easier then the 10-12.
I had Pepboys swap the front springs.  They charged me $52 for the spring swap, and then $89.99 for the alignment. I bought the springs from stage 3 for $262 including shipping.  So for $403 and my labor, the springs are in the car.
On the front, the two large nut and bolts that hold the strut to the brake assembly are splined.  Crack the nut, and bring it flush with the end of the bolt.  Then smack the crap out of it with a hammer.  I didn't realize this and my trusty breaker bar became an casualty.
The rears are really easy. I removed the wheels and tires, and just dropped the sway bar links, and the removed the large bolt that connects the "A" arm into the rear cradle.  Use a jack to lower the "A" arm and remove the spring.  Really easy. Reverse the steps to install H&R springs.  I actually got the rear camber bolts pretty square on with the alignment.  Even the tech was like, you did that?
All in all it was a pretty easy install, but it was brutal on my knees.  I am terrible at documenting things with pictures, but her are the some pictures.  When the car settles I will snap some more.  I have a stock picture, a leveled rear pic (I cut my PP Springs), and I will have my H&R springs picture soon.
I have already noticed better handling and a different ride.  I can't wait until she settles.
Looking GOOD!  Take care of those knees, never a good thing when they start to give ...
SM105K
#6117
Quote from: SHOdded on February 25, 2019, 09:25:35 AM
Three shows in two weeks, averaged 8 miles walking per day last week at work, and four knee operations (two both)....
They were feeling good in January.  I have some rehab planned over the next 6 weeks.  I have terrible Nitro-methane and Sun hangover as well.
StealBlueSho
FINALLY!!! Found a shop within a couple hour drive that has a Mechanically Linked DYNOJET!!!!  I am scheduled for Wednesday afternoon for a dyno session to compare the custom E30 tune from LMS and the E30 tune from Gearhead.
What is REALLY cool is the shop is extremely familiar with the SHO and know Livernois as well. They were talking about a recent build they just did with a customer that included a motor, turbos, etc etc.. excited to see what can be done. They did offer to tune it as well lol..  We will see!
National Speed Inc in Richmond, VA.
