Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
double c
2010 Steel Blue Metallic  Stage 4+ My DD (Gone Girl)
2013 Escape Titanium Sterling Gray Metallic 2.0 EB  XYL's DD
2016 Explorer Sport: Ingot Silver Metallic: CQuartz-Finest My DD
Quote from: EcoBrick Bob on June 28, 2013, 07:01:12 PM
Tomorrow is Flex Day! & Sunday is my Wife's B.Day!!
A very happy BDay to Mrs. EBB!  Good luck w your G8+ :)
Removed all the boost hoses from my Flex except for the bottom one, it's about 116 in my garage so I'll tackle the bottom one under the car in the morning. :)
Timeless
Quote from: DJE624 on June 28, 2013, 03:17:51 PM
Turned 1K on the tune!  Almost raced a 5.0 on the tollway.  I SHO'ed him a little power.  He got off.  Probably scared him.
Be careful of those 5.0s...I came from one with just a tune and it is much faster than our cars except from the dig.
2014 RAM 1500 Sport - Daily
1986 RX7 LS1 SWAP - 305WHP - 2600LBS - FUN
2016 MAZDA CX-5 GT - Wife's
Frozen White with RS2 Package Ordered!
This morning I went out and pulled my engine cover off.  I also took off that black round piece of foam that slips over what I think is a fuel regulator or some kind of vent(?).  (Bright shiny module in the center of front valve cover.) Hopefully it will help the heat dissipate.  Then I detailed the engine compartment.
I also pumped up my tires from 36 to 38 cold.  If you can put 40 in a Flex I figured I could put 38 in a SHO.  I reset the TPMS (a continuing problem) yesterday and thought a couple more pounds might help it from faulting.  Should handle a little better too.
EcoBrick Bob
Quote from: DJE624 on July 01, 2013, 02:07:41 PM
That is the DI Fuel Pump.  I painted my Foam cover with Black Paint.  I feel it has benefit as it keeps some heat from directly getting to DI pump, keeping fuel possibly cooler.
Naples, FL & Clear Lake, IA
Put the foam thing back on, that helps a ton with the noise from CDFP
darreli
The "fuel regulator thing" is the High Pressure Fuel Pump. Putting the foam back on there definitely cuts down on the noise generated by the pump. It doesnt really bother me, so I usually just leave it off
I have to make a few runs this afternoon.  I'll see how it is with out.  EBB-Mine is black so no paint required!   ;D
PopolZ
#55
All the chrome on my SHO beside the chromed ring around the bottom grill of the bumper is now black.
Next step, the wheels :D but it's too windy right now :(
edit: pics :D
yeah it's dirty... i know...
2010 Ford Taurus SHO, non-PP, Steel Blue #243 of 301 - Custom tune by Torrie@Unleashed, PPE non-catted downpipes, custom 3rd cat & resonator delete, water/meth injection, HKS SSQV3 BOV and Carbotech AX6 brake pads.
1991 Nissan Skyline GTR, Pearl Black Metallic - a few goodies
TSS
Looks good. /\
Today I took the car to a trim shop amd had them finally locateand fix a rattle I have been chasing for a year.  Sooooo happy.  It was in the seatbelt base
Quote from: PopolZ on July 01, 2013, 03:20:15 PM
I dig it.  Do you just spray on the Plasti-dip and then trim and peel around it?  How many coats and how long to dry? How many cans did you use?
Quote from: TSS on July 01, 2013, 04:54:08 PM
Looks good. /\
A squeak or rattle would drive me nuts.  I'm glad they found it!
Thanks!  Did you wait an hour between coats?  Or just after the last coat before you peeled.  I was thinking of scoring the edges with a blade?
