February 16, 2019, 01:07:28 PM
Author Topic: JLT Oil Separator  (Read 30740 times)
Offline metroplex
  • EcoBooster
  • Sr. Member
  • : SE MI USA
  • -Given: 3
  • -Received: 39
  • b00st
Re: JLT Oil Separator
« Reply #45 on: January 03, 2017, 07:53:33 PM »
I think it depends on the application. Mustangs have gotten the hard OEM nylon tubing. I also saw the Thermoid air brake hose on other applications. If the engine isn't too boosted or doesn't have a lot of fuel dilution, air brake hose might be ok especall on a Mustang Gt where it may only see oil . As an engineer, I wouldn't even have bothered with that hose material though especially for this application.
2014 SHO
12.4 @ 110.9 mph
Offline ChrisJ
  • Jr. Member
  • : Williamsburg, VA
  • -Given: 0
  • -Received: 2
« Reply #46 on: February 01, 2017, 06:57:41 AM »
I run a JLT separator on my sho. Easy install but I am not noticing nearly the amount of collection some of you are. I went with JLT because Jay has always treated me right. Been using his products since he was making them one off out of requests on forums.
2015 SHO non-pp - LMS catted downpipes, Hotpipes, 50mm tial, 3 br map, airraid intake, magnaflow catback, h&r lowering springs, MSD coils, 542s, JLT v3 catch can, tuned by bcb and some other pretty junk.
Offline MiWiAu
  • : Milwaukee
  • -Given: 244
  • -Received: 326
  • EcoBoobster
« Reply #47 on: February 01, 2017, 10:32:00 AM »
Did your kit also come with air brake hose? Curious if you were/are smelling fuel vapor like metroplex.
If you wanted to increase the efficiency of your JLT, you could also tee into the intake piping to provide PCV evacuation under boost. If memory serves, the JLT only connects to the IM, correct? In this case you would only get vacuum at cruise when you're not running any boost.
My RX collection is mostly water with a little oil. I'm guessing my collection volumes will be much lower when spring/summer rolls around and there is less moisture circulating through the system.
Mikey
2013 XPL0DR Sport
AJP Turbo Tuned
NGK 6510 Plugs (0.030"), 170 degree RAT Stat, AEM DryFlow Filter, AJP Turbo Boost Regulator, Lubed with AMSOIL
Offline ChrisJ
  • Jr. Member
  • -Given: 0
  • -Received: 2
« Reply #48 on: February 01, 2017, 10:40:22 AM »
I think its only on the clean side.
Offline MiWiAu
  • : Milwaukee
  • -Given: 244
  • -Received: 326
  • EcoBoobster
« Reply #49 on: February 01, 2017, 02:10:13 PM »
That's the dirty side, and probably the intake manifold connection. The cleanside port is on the front bank near the oil fill cap. You don't need a catch can for the clean side, since that's primarily fresh air intake into the engine (with an occasional reverse flow burp).
This setup will not evacuate the dirty side during boost, but could be modified to do so fairly easily with some tees and check valves.
Mikey
2013 XPL0DR Sport
AJP Turbo Tuned
Offline AlexAvani
  • Newbie
  • -Given: 0
  • -Received: 1
« Reply #50 on: November 21, 2018, 04:47:00 PM »
I put a jLT Oil separator.  Here is my install
https://youtu.be/EwcZtPXZaKM
* Featured Topics
* Recent Topics
Re: 3.5eco transverse prone to water pump failures?
by ZSHO | Today at 05:13:12 AM
Man if you crack 400 awhp tune only that will be epic!  Since you...
Re: Radar rear view mirror Tap!
by ZSHO | Today at 05:01:17 AM
Glad this thread was of some assistance and straight to the point. Lol...
Re: Ford F150
by SHOdded | February 15, 2019, 10:58:45 PM
February 11, 2019 NHTSA Campaign Number: 19V075000Unexpected Transmiss...
Re: Gearhead Intercooler Review
by TopherSho | February 15, 2019, 07:18:00 PM
I was finally able to get a decent datalog on the new IC.. here are tw...
Re: Flex fuel for 2017-2019 3.5L F-150s available!
by bpd1151 | February 15, 2019, 04:45:25 PM
You read that sm105k? You tickled his emotion chip... lmao...He most c...
MOVED: Gearhead Intercooler Review
by ZSHO | February 15, 2019, 03:49:21 PM
This topic has been moved to Gearhead Automotive Performance.https://w...
Re: Friend looking at 2013 SHO
by ZSHO | February 15, 2019, 02:24:58 PM
FORD TAURUS MODEL YEAR COMPARISON. Zhttps://www.carcomplaints.com/Ford...
Re: Delivery feedback.
by Sabtaj1 | February 15, 2019, 01:14:10 PM
Well they never responded to PayPal so I was issued a refund for my pu...
Re: Lincoln Continental
by ZSHO | February 15, 2019, 09:43:52 AM
LINCOLN CONTINENTAL DOOR LATCH RECALL INCLUDES 28,200 CARSLincoln Cont...
Re: tial wastegate for charge piping
by Brewineer | February 14, 2019, 07:09:53 PM
I read that the reason why wastegates leak around the valve stem in th...
Re: Meth leaK!
by StealBlueSho | February 14, 2019, 04:44:00 PM
And the wind whispers “Ethanol.... intercooler..... “....Nicely done!...
Re: Snow Pics!
by SHOdded | February 14, 2019, 11:30:42 AM
Makes the heart gladder :D...
Re: Map intercooler possibly
by mattr66 | February 14, 2019, 05:35:59 AM
1.  Without major hacking of the crash bumper, a front mount does...
Re: Towing feasibility with a 2013 PP SHO
by Macgyver | February 13, 2019, 04:57:23 PM
Thanks for the feedback!I've got a set of air springs for the rea...
by Jordan | February 13, 2019, 04:08:14 PM
Got my new custom plates in that I ordered half a year ago lol.... &qu...
Back to top
