That's the dirty side, and probably the intake manifold connection. The cleanside port is on the front bank near the oil fill cap. You don't need a catch can for the clean side, since that's primarily fresh air intake into the engine (with an occasional reverse flow burp).
This setup will not evacuate the dirty side during boost, but could be modified to do so fairly easily with some tees and check valves.
