Burping radiator after 170 tstat change?
Started by 2010SHOtime, April 26, 2014, 04:23:48 PM
2010SHOtime
Hey guys,
Maybe this is a silly question but I just got done changeing out my tstat and now I'm curious how do I go about burping the system or if I even need to do it?
Thanks!
2010 SHO 402A non PP. Best time 13.113 @ 105.81
Tuned by Torrie @ Unleashed Tuning, sp534 plugs, 170 t-stat, 3 bar sensor.
2013 explorer (wifeys car)
2002 Orange Camaro SS-sold
Quote from: 2010SHOtime on April 26, 2014, 04:23:48 PM
Hey guys,
Thanks!
Refill the reservoir to max cold fill lin... start the car....Turn on the heater full blast... and drive around easy normal ... (not just idle)... for 20-30 min.  That usually does it.... refill the reservoir again and check it daily for a couple of days (likely won't need more).   The refill can be done with Water Wetter, recommended Ford coolant (see your OM), or distilled water
2010SHOtime
Larrylu
That's exactly what I did and it worked perfectly for me. No problem burping at all!
2010 Steel Blue Metallic, Fully Loaded, non PP, LMS 4+, K&N drop in, 170 T-stat, 3 bar MAP
southtxSHO
Great info , will be doing this tomorrow .Got my 160 t-stat in today
Sent from my SM-N900T using Tapatalk
2011 SHO non PP
LMS 4 +tune
LMS Cai
LMS catted downpipes
12.89@ 105 MPH best time @ Edinburg Raceway
USMCSHO341
How or what is the easiest way to fill the reservoir tank after I swap out my tstat? I'm looking to do this once I get my car back out of the shop. And I would like as much info as possible. Additionally I just got my tunes as well so I'll be loading it up as well.
Parke on level ground.  Right side up on a curb or jackstand to create a high point.  Lisle SpillFree Funnel to add coolant to the degas/overflow bottle.  Then follow the "burp" procedure.  After cooldown, add more coolant as needed.
USMCSHO341
I just removed the tstat housing and pulled the stock tstat. There is a rubber oring on the stocker. I bought a replacement oring for the 160 tstat is that nescessary to place it in there with the 160 stat?
USMCSHO341
Need help asap
USMCSHO341
The 160 stat uses the oem gasket and if you do have a new gasket would definetly use the NEW one.  NEW GASKET AFFIRMATIVE.   BTW the nipple(valve should be facing up(2400hrs)  Z
pmezo33
Might as well use the new one since you bought it.  I used the one that was already in there and it worked fine too, but I just replaced it with an oem motorcraft.
USMCSHO341
Well I installed the tstat and I wasn't aware that the nipple thing was supposed to be at the top. I guess I'll have to work on it again in the morning. I also failed at burping the system. Cold air when the heat is on becomes warmer if I rev to 2k rpm. Drove it around the neiborhood and it started to overheat. So I had to stop and turn it off and wait for it to cool to continue. Before driving I had the RS front wheel up on a ramp trying to burp the system. I guess it didn't work.
USMCSHO341
Quote from: ZSHO on November 06, 2015, 07:13:58 PM
Btw why is the nipple supposed to be up?
Definitely sounds like low coolant/air bubble situation.  You ran the blower at max with climate control on FULL HOT?  Sometimes you have to repeat a few times before it takes, but having the TStat point the right way is mighty important, so I'd take care of that first.
