Upgraded injectors!
Started by ShoBoat, April 23, 2014, 09:27:29 AM
ShoBoat
Check it out, looks like we may finally have a fuel solution!
http://www.stangtv.com/news/deatschwerks-developing-ecoboost-injectors-in-time-for-2015-mustang/
2012 Pearl White CTS-V Stock
Good find!  Maybe a plug and play fuel solution for the masses.
Injectors mean nothing without more pump....
SRT82ECOBOOST
I may be that I just don't know enough about the flow of fluids, but how does a larger injector not allow for more fuel to be delivered?
4dr is right. So based on what has been done so far, by ford racing. Is going to be most likely dual hpfp's. One would imagine they explored modifying the stock pump.
SRT82ECOBOOST
 Isn't some of the pressure seen by the fuel pump due to trying push through the tiny opening in the injector?
Quote from: crash712us on April 23, 2014, 10:33:37 AM
My fuel solution works that I have already to go for you guys, it's been proven again on a truck recently putting down 480HP on stock DI pump and injectors. We're just finalizing the design.
If you want MORE power for your transverse vehicle just have to tap into some wires, the dual fuel pump return system will work for you RIGHT NOW.
Quote from: SRT82ECOBOOST on April 23, 2014, 10:45:11 AM
I can put MASSIVE injectors on my V but if I'm out of pump doesn't matter.
We see falling HPFP pressures at max tunes stock, adding injectors is only going to make that worse.
My fuel system combined with HPFP and injectors should allow for 700+ HP easily on 93 octane. Nobody is making a transverse DI pump though, just trucks.
ShoBoat
Quote from: 4DRHTRD on April 23, 2014, 10:46:13 AM
Wait what? Did I miss something? Please elaborate.
Quote from: ShoBoat on April 23, 2014, 09:27:29 AM
A little behind the 8 ball there ShoBoat  we've been discussing this for awhile now in this thread
http://www.ecoboostperformanceforum.com/index.php?topic=1447.msg39304#msg39304
Neat, but they'll still be starved by OE upstream delivery.
Quote from: SwampRat on April 23, 2014, 11:41:25 AM
Most people can't read every thread, myself included! :)
ShoBoat
Didn't see that thread, thanks.
