3 Bar Map Sensor
Started by RubyRed2014SHO, April 22, 2014, 01:46:28 PM
RubyRed2014SHO
Does anyone know the benefits of installing a 3 bar map sensor from Torrie and can you use an email tune with it? I already have K&N CAI, plugs and X4. Looking to purchase the 3 bar map sensor and down pipes from Stage 3 Motorsports.
Regardless of tuner chosen.... both major tuners have adjustments for the 3BAR MAP that they can just send/download to you... if they didn't your car might not even start.  BTW SW was correct... the $85 RockAuto is turning out to be the correct Ford part, so you can save a $40-$50 ordering it there....
Benefits are:.... 2BAR cannot read or communicate boost above about 14.5psi to the ECU.  3BAR can communicate up to about 29psi.  Your stock turbos probably are incapable of boost over 17psi, but may folks are frequently seeing 16 psi.   The tune is about letting the ECU deal with the information (higher boost) so it is translated into more power, instead of malfunction/DTCs/CELs and wrench lights.
I LOVE my 3BAR tune.... It is a step up from any tune without it...  Why run your turbos to just pump the pressure out the waste gate!?
BTW... try your car with and without the K&N... many... 4DR, bamsho, and others have actually had a reproducible degradation of quarter mile times with the AM CAIs that is fixed in back to back runs, by reverting to stock.   Check out the downpipes thread I put up for more info on this.
RubyRed2014SHO
Thanks BiGMaC. Will definitely look into getting a sensor then!
A little off topic here,for ruby red 14 member,dont take advise from me but you mentioned stage 3 dpipes,catted which I also have on my 13 sho,long story short the throw codes+had to pay extra money for install cause 02 sensors do not line up properly had to do custom work hole is on wrong side.any questions email me
MeanKS
so then, how good can a tune be without 3 bar mapping?
all of a sudden, it seems like many are almost saying 'whats the point w/o it?'  ???
I definitely want my car to be faster, but i also want it to be around for a while as my daily driver...
MKS-EB...
Livernois Motorsports
Quote from: BiGMaC on April 22, 2014, 02:20:35 PM
BigMac is correct on this.
To run a 3bar you need to have a custom file written for it or it will not run correctly.
Quote from: DRII on April 22, 2014, 04:17:04 PM
Anything you do to improve performance will cause some degree of faster engine wear.... LMS will err on the conservative side historically... does not mean a sacrifice of performance.... unaware of any engine failures  and some members have been tuned for 40K-50K miles.
RubyRed2014SHO
I definitely appreciate the info guys. Will definitely look at Livernois down pipes if you had that many issues with Stage 3 zamirlihari.
Whereabouts are you located, RubyRed?  Might be able to save on shipping if close to either Michigan or Texas.  To my knowledge, the top 2 downpipes that pass emissions are from PPE (http://shop.ecoboostpowerparts.com/Ford-Flex-SHO-Lincoln-MKT-MKS-25-Pipe-w-cats-PPESHOCats.htm) and LMS (http://www.livernoismotorsports.com/products/Livernois-Motorsports-EcoBoost-SHO%7B47%7DMKS-Downpipe-%28Catted%7B47%7DOff%252dRoad%29.html).  Many happy customers for each.
RubyRed2014SHO
Well I live in the Tampa Bay area but I'm on assignment for work in Nebraska. I will have the car up here with me next week. I will actually be visiting friends in Louisiana in the near future. Where in Texas?
Oops, I should have said AZ.  PPE's facilities are in Tempe, AZ.  https://www.ppeengineering-onlinestore.com/contactus.sc
Quote from: SHOdded on April 22, 2014, 06:22:36 PM
Very familiar with it... and memorized the drive from there to Black Market Racing for dynos!
REDSHOCGO
Quote from: RubyRed2014SHO on April 22, 2014, 01:46:28 PM
thread can be found here http://www.ecoboostperformanceforum.com/index.php?topic=2558.msg37982#msg37982
2010 Red Candy Sho 402a option non/pp w/unleashed tune,3 bar map, k & N CAI, Corsa catback exhaust, tints 35% front 20% back vta conversion,plastidipped front grill (matteblack), Curva Concept C7 wheels w/20" toyo proxes +4 and Sony Xperia z running torque pro
2011 Sonata 2.0T Limited tinted
2007 Pontiac G6 GTP cpe w/crab intake,Led sequential taillights, custom exhaust(now gone)
