Question for all of you, since we are in this department,when the car is on, and even without this cover on, I can hear this vacuum noise (sucking, as in a boost leak) coming from the firewall, someplace from the rear turbo to the valve cover closer to the cabin. The noise is only noticeable at idle with the hood up. I was curious if you hear this noise on your car, and if it's normal?
