I wouldn't expect much of anything in only 310 miles of testing .
It has been conclusively proven that the PCV system on the SHO and other DI engines contributes to the detrimental inherent issues that DI engines have .
I have stated that the torture test / tear down video that Ford uses is nothing more than a marketing tool and I love my Ford's.
Just as many here have done the the BOV VTA ( no no says EPA ) the only way to eliminate the deposits and harm associated with PCV systems is to use some type of containment system or vent the crankcase to air . This could be done ....... Not an ideal solution but for off road , its common place .
BG's real world 60,000 mile testing of there company owned 2010 SHO proves this .
http://www.bgprod.com/bgfueltest/ Perhaps longer testing on your part may show accumulation , my guess is even though the Moroso cans MAY not be the ideal choice ; the plumbing choice or PCV routing needs to be reconsidered .
You MAY end up with accumulation results with this test with more time and driving .
Weather or not this oil is bulding up from leaky turbo seals or a poorly designed PCV system or a combination of the two , you still have a need to remove it from the intake CAC and associated plumbing to prevent these harmfull deposits and other internal component damage from occuring .
I plan on keeping my SHO a VERY long time and anything I can do to keep things purring is worth the investment .
Tracy readily admits there are SOME OCC's on the market that are good ones but most are garbage.
I appreciate his honesty but most of us here are not knowledgeable enough to buy one from whomever else and hook the plumbing up correctly .
Tracy at RX did a fix as he determined the initial install on painterpats Flex by him was faulty . We will see soon whether or not this has been remedied , I think it will end up with possitive results .
His F150 system works as stated , I think its simply a matter of working out the bugs .
