Started by jtoddk98, April 10, 2014, 09:02:44 PM
Quote from: SHOdded on September 17, 2014, 07:24:26 PMSo you watch WD with Mike & Ed, eh? Here's their procedure for cleaning the intake valves on GDI engines.
Quote from: SHOdded on January 08, 2015, 12:37:57 AMHa! He shows a RevXtreme catchcan during the video. Apparently excessive blowby (byproduct of turbo function) pressurizes the crankcase and thus forcing even more c*** through the intake onto the back of the intake valves.
Quote from: BiGMaC on January 08, 2015, 01:16:45 AMIt's another reason to be VTA... At least then there's no recycling the stuff. Even with the can you need a clean side separator.
Quote from: J-Will on January 09, 2015, 10:11:50 AMQuote from: BiGMaC on January 08, 2015, 01:16:45 AMIt's another reason to be VTA... At least then there's no recycling the stuff. Even with the can you need a clean side separator.Is this the only form of EGR, or is there a traditional method as well?
Quote from: J-Will on January 09, 2015, 04:23:59 PMYes it does help. I was asking to get a better understanding of what would need to be blocked in order to prevent all exhaust gases from re entering the engine. It was common practice on previous cars to throw on a block off plate, and use HP Tuners to disable CELs. I am wondering if anything other than changing to VTA would need to be done in order to prevent all exhaust gases from recirculating. I am also wondering why LMS would say that they see no benefit from VTA.
