Quote from: Colorado-SHOBro on January 15, 2017, 01:02:12 PM
Resurrection once again!! haha
Just purchased JJ's RX standard can kit and am already busy planning the install. Couple general questions. From reading all the how to threads etc. it looks like the options are- (please correct me if any of the following is false)
Clean side setup:
1.Vent CSS to atmosphere w/breather filter(which tends to get oil soaked and leak vapor in the cabin)
2.Tap into the airbox (which could accumulate oil in the airbox unless a check-valve is used?)
^if tapping into the airbox does it need to be pre or post filter?
Can the CSS be removed and factory oil cap replaced while still leaving the dirty OCC side connected without harm to the operation of the system? This would be to avoid red flags on dealer visits.
Vacuum source:
Was it ever determined if both areas of the charge pipe(front side OEM port+rear BOV port) need to be used with the T or is one vacuum source sufficient?
^the answer to this question might determine if it's possible to run the system with the factory oil cap as a the OEM piece from front cam cover to charge pipe source would need to be installed when doing so. . If i'm not mistaken.
Did my best to get up to speed on everything before posting so hopefully the questions are clear.
Thanks to all members for their in-depth documentation of installs and results! Great community here!
Hey Nutz, sorry I missed your questions here. A little tardy with my reply, but in case someone else comes along...
Re: CSS
1. This is how I have mine. I have not noticed any offensive vapors or oil on my filter yet.
2. You want to tap the clean/filtered (top) side of the lid, so you are not pulling unfiltered air into the engine.
Re: Vacuum source
On the intake pipes, I recall seeing a post from Tracy (original designer of RX can) that one intake connection is okay, but two is better. Typically, a single connection would be on the fore most pipe where the cleanside quick connect attaches, for ease of install. A second source can help improve efficiency and provide, I imagine, slightly more vacuum and evacuation when under boost. I opted to use two intake sources for maximum evacuation.
Technically, you could leave the cleanside hooked up to the intake pipe and use the factory oil cap, but IMO, this still leaves a potential for oil to get drawn back into the intake piping. If a CSS breather filter is getting oil soaked, why would one expect oil to not migrate to the intake end of the cleanside tube? Once oil is in the intake, there's nothing keeping it from eventually getting to your valves, so on my install, I decided to completely remove that connection. The only way oil will enter my intake now is from turbo blow by. Hopefully I'm a ways off from that...
