After much back and fourth emails with Tommy from Rx Speed Works (who was incredibly helpful and quick to respond, even at 10pm), I can now suggest a much simplified install. I am assuming that you read the initial instructions, so I will only amend them here and provide the following main points:
1. The 90 degree tube from the PCV valve on the passenger side of the engine: Do not cut the tube to remove the OEM quick connect fittings. Heat up the tube at connection points with a heat gun and the fittings will come out without damage to the tube or themselves.
2. Side note: 2015+ models have an EGR sensor in the pipe in the front of the engine connecting the port to be capped to the port on the passenger side turbo inlet pipe.
3. The can kit should come with an adapter that allows you to connect an OEM quick connect fitting to a 1/2" hose. My kid did not include it and this came up in my conversation with RxSW. They are sending me one. If you do not receive it as a part of the kit, call them and ask them to send it before you do anything. This allows you to install the right can line to the passenger turbo inlet pipe WITHOUT drilling any holes.
4. Only one connection to the turbo inlet pipes is required. You DO NOT need to drill the drivers side turbo inlet pipe (you could, if you want full system efficiency). If you choose to drill ut, do not drill in the seam of the pipe, like I did, and split the pipe when tightening the fitting. I know... it was brilliant
So to summarize, the only permanent modification to OEM components that you need to perform is to drill the lid of your intake box for a CCS connection. That's it.
See the diagram below.
[/URL][/url]
