Definitive EcoBoost Exhaust Sound Thread
Started by thatsmrgimp2u, March 29, 2014, 05:11:38 PM
SRT82ECOBOOST
thatsmrgimp2u
The less restrictions you have the louder your turbos get. Take out cats, turbos get louder. Take out the factory resonator and put some straightflow mufflers in they get super loud. Mine were louder without the vibrant s, but not much.
2011 ISM SHO;  SCT X3 (Unleashed), Airaid Intake, PPE Downpipes, Magnaflow Mufflers and X-pipe with Vibrant resonators, 170 Thermostat, H&R Springs, RX CSS
12.91@107
JimiJak
Thanks!
Intake or hot pipes have much of an effect on it? Or mostly just exhaust stuff?
2014 XSport Black Betty Build
SHODYOU
Just exhaust stuff... muffler swap made em audible. 3rd cat/res delete, even with a muffled x and they were pretty noticeable.
Catless dp's and under any load its whistles... great to hear em reflecting off cars/buildings/trees while you have windows down.
FracaSHO
#34
Does anyone have or can make a video of how a Corsa exhaust sounds from inside their SHO while cruising at highway speeds? With or without DP's.
Please and thank you.
Brad
2010 SHO with PP
170* T-Stat
NGK LTR7IX plugs, gap at 0.030
BOV VTA
MyCal LMS Stage 4+
Sent from my iPhone
Brad
2010 Tuxedo Black SHO w/ PP
Quote from: FracaSHO on April 19, 2014, 11:25:19 PM
Brad
2010 SHO with PP
170* T-Stat
BOV VTA
MyCal LMS Stage 4+
Sent from my iPhone
Video clip rolling down the road ... Corsa with PPE non catted
http://youtu.be/tnx6dIRq6ps
Admin
SHODYOU
I was about to say... its basically useless to try to video.
Even with my catless dp's at hwy speed the tires and wind are louder. It falls a distant 3rd in the noise category unless im giving it throttle.
JimiJak
#38
Alright...first off: Thank you all for this excellent resource!
Second: (edited to make more sense)
Has anyone heard flowmasters on a transverse?
What I'm really trying to isolate from all these videos is the rasp. So what is it exactly I want to stay away from?
I'm thinking 2.5" or 3" non-catted DPs, 3" back to magnaflow Tru-X 3" crossover, 3" back to MBRP, Corsa, or Flowmaster 10s, out to 4 or 5" tips...good idea / bad idea? Hoping for something original here, that fits my taste...
Also, anyone heard any updates to the 3" downpipes @adrianMAK had in development? I haven't seen anything posted since May...
JimiJak
:chop:
Whelp...that must have done it...not sure what I asked that put it over the edge; but sorry I suck and killed this thread. :axe:
SHODYOU
I would not run anything chambered (flowmaster or knockoff) on a turbo vehicle.
The pulses it creates sends a wave back into the turbo and kills power.
The way they work is by pulsing the exhaust in the chambers to create a vacuum that supposedly sucks out more exhaust, but turbos hate it.
Post turbo exhaust should be about removing any and all restrictions post compressor.
Stick with a straight thru type... if you want a deeper flowmaster type sound (but no hollowness) go with a Mac FloPath or Spintech.
Neither are a true straight thru but neither design slows down exhaust flow.
Quote from: shoman04 on March 31, 2014, 08:09:27 PM
Quote from: shoman04 on March 29, 2014, 11:07:34 PM
Here My LMS down-pipe, MagFlo 2.5" x-pipe, 2.5" exhaust, & DynoMax Mufflers.
https://www.youtube.com/watch?v=eQu5Fnpx7zs
Many people have ask about how quit is the car with the 3rd cat remove. Here my car stock mufflers on for a road trip with WIFE!!!!!! IT SOUNDS STOCK EVEN WITH ALL THE MOD's I HAVE!!!!!!! WOW
STOCK EXHAUST 2
Catted or catless dp's?
This is my favorite setup.
I prefer stealth and the tone of the stock mufflers.
It would be awesome if you swapped your setup at the strip sometime.
JimiJak
Quote from: thatsmrgimp2u on April 15, 2014, 08:03:26 PM
Well my exhaust is done. Wound up with a 2.25 xpipe, 2.25 vibrarant resonators, and two magnaflow mufflers with cherry bomb tips. Im finally happy with the sound. The resonators are a must have in this setup. Ill get a video up this weekend.
Any luck with the vid? TIA
JimiJak
For more info on this exhaust, more videos...and a boat-load more pics, check out THE FULL WRITE UP
MDesigns Exhaust Prototype
Stock air box + K&N Panel Filter. No engine mods. No tune.
http://youtu.be/y9wq6Zn83xM
bigmoneycloser
Do you have this VTA?
2014 Explorer Sport 401A
