- The Magic Boost Bus
- Full Member
- So Flexy
- Logged
Quote from: Ramairetransam on March 22, 2017, 09:50:09 AM
I am ordering my tips today , 4.5inch . What size is the stock pipe going into the muffler is it 2.25? I plan on doing the muffler delete at home with my brothers welding skills. Also does anyone know if a muffler delete can be done with just straight piping or do i need it to be bent a little?
I definitely had to deal with some bending to get the tip centered. I came into it thinking just a couple straight pipes, clamps, and pipe mating joints were all I needed. Then I cut my mufflers off and realized the angles were all over the place. Our mufflers aren't center-in, so it takes some work. We ended up doing it the right way and welded the pipes on, in two sections instead of just one, and then took a torch and heated up the main bend and pulled the whole straight pipe into place the extra inch that was needed to center my tips. Hangers will end up being another challenge you'll face. Be prepared for the worst lol. I luckily was working with an experienced old-school mechanic (my buddy's Dad), so he figured things out relatively easily after studying the whole thing for a bit and making changes on the fly. I can honestly say I wouldn't have got the job done without a welder, a torch, and his knowledge.
2014 Ford Flex Limited AWD EcoBoost - Full Amsoil Synthetic Fluids swap in engine and driveline, SCT X4 Tuner w/ multiple tunes for 93 + Meth, Dash-mount Tablet running Torque Pro Gauges w/ BT Wireless OBD Adapter, 170 T-stat, 3-Bar MAP sensor, Denso 1step Colder Spark Plugs, OBX Catless Downpipes, Magnaflow Downpipe-back 2.5" exhaust system, Magnaflow 2.5" X-Pipe, MDesign Carbon Direct Cold Air Intake (Latest Gen), UPR 3-way Catch Can System, Devil's Own Stage-2 3-Bar Methanol Injection System with custom Tank/Pump mount, EcoPowerParts Black powder-coated Charge Pipe kit, TIAL Q Race BOV in Ruby Red color-match, Power Stop Z23 Brake upgrade on all 4 corners with Drilled/Slotted Zinc Rotors and Carbon Fiber-infused Ceramic Pads with color-matched Ruby Red calipers, Moog upgraded Sway Bar Endlinks, lowered on Megan Racing EZ Street coilovers, SPC Rear Camber kit, Verde Axis V99 Bronze 20x9 wheels wrapped in 275/40 Nexens, Custom forged 4 1/2" spiked one-piece steel lugs, Kicker CompRT 12" Sub in custom spare tire-well box, Polk Audio Carbon C500.1 mono sub amp, All-Fit Front Lip Spoiler, 3D Carbon Rear Wing, Ruby Red vinyl wrapped interior trim, LED-lit "FLEX" Door Sills, Full LED Interior bulb swap, Red LED Accent lighting throughout, SpiderMax 3D Kagu black laser fit floor mats for all 3 rows, LED Puddle Light swap, Tinted LED Tails, Windows Tinted all around.
