Definitive EcoBoost Exhaust Sound Thread
Started by thatsmrgimp2u, March 29, 2014, 05:11:38 PM
While not a "sound" post, here is an example of a resonator used to help reduce drone.  If you are otherwise happy with your exhaust mods, this would be a good addition:
http://shoforum.com/index.php?threads/fixing-the-drone.133170/
paokara777
Bigfoot's SHO with a muffler delete sounds epic!
Do any muffler shops do this or do you have to find one willing to remove mufflers "hush hush"
Daily Drive:
2010 Ford Taurus SHO, AJP 3BAR 93, K&N drop in
Weekend Cruiser:
1968 Ford Mustang Coupe 289 C Code
4Bl Carb, HiPo Cam, Headers and Exhaust
To date, muffler removal has not been an issue.  Catalytic converters, whole another story.
paokara777
Then this will be my next mod. I gotta have that sound
Daily Drive:
Weekend Cruiser:
salsathe4th
#111
Is this what everyone else's sounds like with just the third cat and mufflers removed? Because damn does this sound good.
https://www.youtube.com/watch?v=EUbpz695cL8
"Do or do not, there is no try"         2010 MKS, 22" Motiv Maranello Rims, Mdesign CAI with VTA, LMS 4X tune and lovin' it
-master yoda
BOT_ROCKET
'17 Fusion Sport 2.7l Ecoboost AWD
Ortiz Tune  (in progress)
2017 Ford Fusion Sport, 1st stock run: 8.98 @ 77.15 MPH
derfdog15
2015 SHO PP
Stock downpipes, resonator replaced with X-pipe, OEM mufflers replaced with Summit Race Mufflers, otherwise stock car
https://www.youtube.com/watch?v=MMemSfOHl9U
Mods for the following: Airaid CAI, EPP hotpipes (noisemaker deleted/replaced with TiAL wastegate), and TiAL BOV replacing OE BOVs
Catless Stainless Works downpipes, resonator replaced with X-pipe, OEM mufflers replaced with Summit Race Mufflers
Idle: https://www.youtube.com/watch?v=S4NmDviFHrM
Neutral Revs: https://www.youtube.com/watch?v=sBVDsPlNtMs
On the dyno: https://www.youtube.com/watch?v=WQlkF54XZ-E
Colorado-SHOBro
Quote from: derfdog15 on January 19, 2017, 07:14:23 PM
2015 SHO PP
I assume you just used a regular x pipe piece not a resonator style x pipe? Hows the drone?
12.8@108 @ 6,000ft DA.
derfdog15
Quote from: Colorado-SHOBro on January 19, 2017, 09:30:58 PM
2015 SHO PP
Correct, this is the X-pipe: https://www.summitracing.com/parts/jex-sxp4/overview/
Drone is definitely there at highway speeds, but not too bad IMO, then again I am used to a mustang with drone-masters so there's that, and my F150 had glasspacks on it. I'm kinda desensatized to drone honestly.
The drone seems to be there around 55-60 and ~68-75 or so. I know its there from turning the radio and A/C off to see if there was some, but for the most part with the radio on, even pretty low, and especially with climate on, its almost impossible for me to tell.
I just bought a go-pro (shoutout to Mike A.K.A MiWiAu ) so I'll get some driving clips once that gets here, and share em for you guys.
derfdog15
Here is a clip of my setup in a parking garage, with BOV sound as well.
https://www.youtube.com/watch?v=lwQnnoBbzyE
Djxfactor  [2014 Ford Flex]
That's a cold-start vid.  Rear Muffler and 3rd Cat delete on an otherwise factory exhaust.  Tips came from two donor 2014 Honda Civic SI's (both buddie's cars already had swapped their exhausts and had their tips sitting in a box) if you can believe it!  The tips fit the oval bumper cutouts just about perfectly and you can't beat free!!
ftp://! No longer available
djxfactor
#118
Quote from: ZSHO on March 20, 2017, 11:35:43 AM
Djxfactor 2014 Ford Flex.
I was just about to head over here and post that vid Z! You're quick! LOL
Just to fill in the info...
2014 Ford Flex Limited AWD EcoBoost - Full Amsoil Synthetic Fluids swap in engine and driveline, SCT X4 Tuner w/ multiple tunes for 93 + Meth, Dash-mount Tablet running Torque Pro Gauges w/ BT Wireless OBD Adapter, 170 T-stat, 3-Bar MAP sensor, Denso 1step Colder Spark Plugs, OBX Catless Downpipes, Magnaflow Downpipe-back 2.5" exhaust system, Magnaflow 2.5" X-Pipe, MDesign Carbon Direct Cold Air Intake (Latest Gen), UPR 3-way Catch Can System, Devil's Own Stage-2 3-Bar Methanol Injection System with custom Tank/Pump mount, EcoPowerParts Black powder-coated Charge Pipe kit, TIAL Q Race BOV in Ruby Red color-match, Power Stop Z23 Brake upgrade on all 4 corners with Drilled/Slotted Zinc Rotors and Carbon Fiber-infused Ceramic Pads with color-matched Ruby Red calipers, Moog upgraded Sway Bar Endlinks, lowered on Megan Racing EZ Street coilovers, SPC Rear Camber kit, Verde Axis V99 Bronze 20x9 wheels wrapped in 275/40 Nexens, Custom forged 4 1/2" spiked one-piece steel lugs, Kicker CompRT 12" Sub in custom spare tire-well box, Polk Audio Carbon C500.1 mono sub amp, All-Fit Front Lip Spoiler, 3D Carbon Rear Wing, Ruby Red vinyl wrapped interior trim, LED-lit "FLEX" Door Sills, Full LED Interior bulb swap, Red LED Accent lighting throughout, SpiderMax 3D Kagu black laser fit floor mats for all 3 rows, LED Puddle Light swap, Tinted LED Tails, Windows Tinted all around.
I love the cold start up.....where was the free revs?..complete the vid
