Quote from: IHeartGroceries on March 12, 2014, 07:26:43 PM
I'm on the E for tuning side.
For TUNING.
Not the running E, hoping Ford built in some kind of magical mystery tune in the stock ECU tables.
My point was, there's mistruths about ethanol in general here.
To argue about quality and such for ethanol heavy fuels, but ignoring all of the potential quality problems in Super grade is ridiculous.
My photo was just used as a credential.
I'd been asking about this in other threads, before I knew this thread existed. My concern has always been the fueling capacity. It is the same concern that crops up on every forum for every platform, interested in tuning for E. I wish those in the know would post data or proof regarding the upgraded fuel system in the 13+. So far, there's not even agreement on that. So, I'm still wondering where's the data regarding the OE equipment limitations. Hardly anybody runs pure E85 anyway. E30-E50 works fine, stays safe (avoiding gumming issues and such), and produces results. And likely does away entirely with messes like water meth injection.
Regarding your claim of "magical mystery tune"
"In order to maintain proper fuel control, the PCM strategy needs to know the stoichiometric Air/Fuel Ratio for use in the fuel pulse width equation. On pre-2000 MY flex fuel vehicles, the percent alcohol in the fuel was determined by reading the output of the Flex fuel Sensor. The percent alcohol was stored in a register called Percent Methanol (PM). Although current alcohol-blended fuels only include ethanol, the percent methanol nomenclature has persisted. On 2000 MY and later vehicles, the Flex Fuel Sensor has been deleted and PM is inferred. The strategy
to infer the correct A/F Ratio (AFR) relies on the oxygen sensor input to maintain stoichiometry after vehicle refueling occurs. "
Please note that 2000 + MY are referred to as vehicles, and does not say flex fuel specific, unlike the description of pre 2000. This coupled with Ford's recent approval of e-15, one could infer that this tech is already built in to the ECM.
There is a crapload of Motorcraft info at this link.(PG 62 starts fueling info)
http://www.motorcraftservice.com/vdirs/diagnostics/pdf/obdsm1202.pdf
