Started by Joleat, February 27, 2014, 10:38:56 PM
Quote from: IHeartGroceries on February 28, 2014, 08:23:15 AMReminds me of a common issue found on the Mazda MZR, which was due to a faulty lock pin in the variable valve timing actuator - number one symptom is a loud ticking/clacking for only the first couple of seconds at start-up. And it was due to slack in the timing chain, and the chain slapping against the underside of the valve cover very briefly. VVT issues? Is that what you speak of? Always began on cars with around 50-75K miles on the odo. Sent from my SM-N900V using Tapatalk
