Ecoboost PCV issues
Started by Tuner Boost, February 23, 2014, 05:25:16 PM
Quote from: BiGMaC on April 07, 2014, 01:15:05 PMDI seems to be the root of the rec per Anthony.....
What is "rec"?
Quote from: SwampRat on April 07, 2014, 01:23:47 PM
Livernois says NO to RX install ..
I think you may need to chime in on this ...
http://www.ecoboostperformanceforum.com/index.php?topic=2142.0;topicseen
PM sent to TunerBoost  .... he's off line and should get PM email .
bigmoneycloser
Oh boy..
2014 Explorer Sport 401A
ShoBoat
Anthony is supposed to get back to me also on this another issue. I'll let you know what he says hopefully today.
2012 Pearl White CTS-V Stock
Tuner Boost
The RX cleanside separator is similar to GM's $190 plastic unit that is an empty canister, but the RX unit is metal and has a removable top and coalescing media in it:
This captures oil during the brief transition from non-boost to boost operation so it can be drawn back into the cam cover on the drivers side.
As for wanting all this gunk entering the intake air charge, and creating the deposits that disrupt air flow past the valves, and also form on the valve stem wearing out valve guides rapidly, and the detonation this oil/gunk mix causes, I can't imagine anyone wanting this to be drawn into any engine:
https://www.youtube.com/watch?v=dT0kpHpGQJ8
Also, with all the issues this corrects, the shudder under boost, the unburnt fuel accumulating in the crankcase oil, the water/sulfuric acid/gunk in the crankcase and the CAC, I would really like to hear of anything this could be "good" for.
Just like with the magnasun top mount supercharger intercoolers clogging with baked on oil residue:
(this was at 15K miles!!!)
.............  there can be nothing but harm from allowing this ingestion, especially with a direct injection engine.
Quote from: ShoBoat on April 07, 2014, 01:43:57 PM
As this is a major issue for many of us here , a LOT of the RX evac systems have already been Sold to members .
Perhaps a member that is a customer of Livernois  could request them to respond directly to us on the forum .
ShoBoat
^^ agreed, I will ask him to do so once I have spoken to him.
ShoBoat
#67
Ok so this has been freaking me out, and I can't find a negative effect on DI engines for adding Catch Cans. Don't know specifically about the RX can's design. Which I have questions about later on that.
BTW BMW does have an OEM catch can on their DI and turbo DI engines. And the PVC on the EB cars does drain and catch some of the oil vapors back to the valve cover. According to some other reading, it's probably not enough, especially on tuned and modified cars. I think the real problem with the EB is that under heavy boost the gasses are now being drawn out the "clean side" and considering that under heavy boost there is now a good amount of vacuum at the port just upstream from the turbo inlet (Venturi effect) the oil is literally being sucked out of the engine. With the guys running Meth this isn't such an issue due to the cleaning and octane raising qualities of the Meth. I will post my question regarding the design of the RX system a bit later.
Have a read below.
Direct Injection Fouls Some Early Adopters
By AutoObserver Staff June 15, 201
In their efforts to wring more power and efficiency from the internal combustion engine, automakers are increasingly turning to gasoline direct-injection technology – also known as GDI or DI. Originally developed to produce more economical and quieter combustion for diesel engines, DI is inherently more efficient and helps generate more power than port injection. And advances in engineering and engine management, fueled by fierce industry competition and consumer demand, are making DI technology more cost-effective than ever for manufacturers: gasoline DI engines are appearing in entry-level models from Ford Motor Co., General Motors Co.'s Chevrolet and Hyundai Motors. Currently, more than 60 2011 and 2012 models in the U.S. offer DI engines as standard equipment.
But there has been a dark side to the technology: carbon build-up around intake valves that, over time, can degrade power and efficiency, eroding the bonus DI is supposed to provide. While there's evidence that the most recent designs and technical enhancements have greatly reduced the issue, carbon buildup has been a distinct and well-documented issue in some DI engines from a variety of manufacturers over the last few years.
Known Problems
A U.S. patent application filed in 2002 by Volkswagen AG explains the DI-engine carbon-deposit dilemma this way: "Gasoline engines with direct injection of the fuel into the combustion chamber...suffer especially from the problem of the formation of carbon deposits...especially in the neck region of the intake valves."
The document describes these deposits as a sticky coating of oil and fuel constituents that, once formed, serves as a base for further deposits, creating "a circular process, by which the coating thickness of the carbon deposits continuously increases." Excessive carbon deposits "have extremely negative effects," the patent application concludes, citing significant performance losses, sporadic ignition failures and, potentially, holes burned in the structure of the catalytic converter (should bits of carbon break from the valves and pass though the combustion chamber).
Ameer Haider, GM's assistant chief engineer for V6 engines, certainly knows the problem, telling AutoObserver, "DI engines are prone to forming oily deposits on the intake valves, unlike in port fuel-injected engines, where a constant spray of fuel into the port allows any deposits to wash away. With DI engines, the fuel gets injected directly into the combustion chamber, so there isn't a chance for the deposits to wash away. Typically, deposits form when soot – which is an end-product of combustion – adheres to the valve stem."
The main purpose of VW's patent application was to propose a fix for DI engine carbon deposits: specifically, applying "a catalytic surface" to the engine valves that "counteracts the formation of carbon deposits." But nearly 10 years later, there's ample evidence that this and other potential solutions have failed.
Constantine Boyadjiev works as a risk management officer at a financial firm in New York and has been an auto enthusiast for most of his life. In 2008, he decided it was time to part with his beloved 2001 BMW M5, mainly due to escalating maintenance costs – but also because he discovered that a number of fellow owners were dealing with expensive-to-fix carbon build-up in their vehicles' engine cylinder heads.
When Boyadjiev replaced his BMW with a barely-used 2008 Audi RS 4, he thought he had put all worry about carbon build-up behind him. But, as he said, "Little did I know that there was a much uglier carbon-build-up problem awaiting me." Boyadjiev became involved with the online RS 4 owner community when he was searching for his car, in particular a group of veteran Audiworld.com members who later migrated to QuattroWorld.com. He kept active with the group as he took delivery of the car and enjoyed the first few months of ownership. Not long after, though, he was dismayed to see that "the message boards caught fire with plenty of formally documented cases" of carbon build-up with fellow RS 4 owners' engines.
Boyadjiev admits to some initial "wishful thinking" that perhaps the problem might only affect earlier production models or that the forum members were merely trumpeting an isolated issue. But then, despite his own "religious" maintenance practices, including using only 93-octane premium fuel and avoiding short, in-town trips that failed to bring the engine up to proper operating temperatures, it soon was apparent his Audi's 4.2-liter direct-injected V8 also was plagued by carbon buildup.
"The loss of performance became very noticeable over time," he says. He decided to document it, taking the car to a local automotive performance specialist in nearby Stamford, Connecticut, to have its power measured by a dynamometer.
At its first measurement, Boyadjiev's RS 4 had 15,000 miles and produced 324 all-wheel horsepower, measured at the wheels (AWHP). Roughly one year and 5,000 miles later, the same test showed 317 AWHP. After another year and 5,000 miles, power was down to 305 AWHP. Power from the 4.2-liter V8 had degraded by almost 5 percent in just 10,000 miles.
Considering the RS 4's performance pedigree – and correspondingly large price tag (in excess of $70,000 MSRP) – this was an alarming trend, something Boyadjiev thought Audi would want to address head-on, especially since parent company VW had earlier documented these very issues in its DI engines. But Boyadjiev and his fellow RS 4 owners found Audi quick to dismiss the issue as a byproduct of poor-quality U.S. gasoline and American-style driving habits (i.e. the absence of high-speed runs on the Autobahn). Audi offered no assistance.
So Boyadjiev took an action to which many other RS 4 owners already had resigned themselves: he had an independent mechanic disassemble the engine and clean it – a $1,200 expense at the time. He returned to the dynamometer to see if the cleaning had made any difference. It had. Engine output soared by 41 AWHP and the car felt new again. For the moment, at least.
Boyadjiev said he is prepared to pay for such a maintenance cleaning every 10,000 miles. And while he is certainly not happy about that, he's willing to endure the hassle and cost. "The car is so rewarding and a joy to drive," he says. He is far less complimentary about Audi's response to the issue. Despite the evidence Boyadjiev and many of his fellow RS 4 forum members have presented, "the company continues to deny this is a very serious issue," he said. "I have very little respect for a company that refuses to stand behind its name, especially when professing a motto of 'Progress through Technology,'" he added. And experiences like Boyadjiev's are not uncommon.
A Google search for "direct injection carbon build up" reveals a flood of owner complaints about the issue across vehicle brands and models, including particularly active threads for the VW GTI, the Lexus IS 250, and a variety of Audi models in addition to the RS 4.
All Engines Not Designed EquallyMany automakers' gasoline DI engines do not appear to exhibit any carbon build-up issues at all, however. Digging into online threads about Cadillac's 3.6-liter DI V6 in its popular CTS lineup does reveal some owner concerns about carbon build-up, but it's difficult to find even a single report that any build-up has actually occurred – a record that is notable considering that Cadillac has sold more than 200,000 CTS models with DI V6s (Audi sold fewer than 2,000 RS 4s in the US during its two-year sales run).
Haider, GM's V6 assistant chief engineer, explained how GM has designed its DI engines to combat carbon buildup: "We maintain great engine function and performance in our all our DI engines through an optimization strategy with our valve events," he said. "Our intake-cam timing, injector targeting and timing of the injection events are optimized to avoid direct fuel contact on the intake valves. This strategy keeps smoke and soot formation to an absolute minimum, which in turn prevents excessive deposit formation."
At the Detroit Auto Show in January, Ford was confident enough about its popular 3.5 liter EcoBoost direct-injection V6 to have technicians tear down an example engine that had accumulated the equivalent of 160,000 miles through an intentionally abusive regimen of log dragging, high-speed towing and desert racing. When they opened it up before a live audience, they found some light carbon deposits on the valves and pistons, but not enough to affect performance. In fact, the engine showed a loss of just one horsepower afterwards – roughly what Boyadjiev's RS 4 engine lost every 500 miles.
Stephen Russ, technical leader for combustion for Ford's 2-liter Duratec DI engine, said that similar to GM, engineers have determined the proper injection-timing calibration to help eliminate the carbon deposits. But Russ also said the technology of injection components – particularly the high-pressure solenoid injectors – has quickly matured, meaning excess valve deposits in most DI engines should become a thing of the past as these improved components are incorporated into production.
Tony Chick, principal engineer at European Performance Labs in Stratford, Connecticut, has made a career of repairing and rebuilding high-performance engines from Audi, Porsche AG and BMW, among others and his operation has garnered a reputation among car enthusiasts as a go-to place for cleaning DI engines that have become choked with carbon. Chick thinks the problem for most affected engines can be traced to the breathing system – specifically, the design of its crankcase ventilation and exhaust-gas recirculation components.
All modern gasoline engines return some crankcase and exhaust gases back through the intake manifold in order to help control emissions, but, according to Chick, some exhaust-gas recirculation designs are "dirtier" than others. Some, he said, are less-effective at preventing the passage of tiny bits of oil, carbon and other particulates that eventually get baked onto the intake ports and valves.
Chick reached his conclusion after inspecting dozens of different DI engines at his shop and finding some, like the V8 in Boyadjiev's Audi RS 4, regularly choked with carbon while others, like the DI version of Porsche's horizontally opposed 6-cylinder, remained much cleaner.
If he's right, the rapid adoption of DI has actually illuminated an issue, not caused one. A "dirty" intake or exhaust-recirculation design can easily go undetected in a conventional port-injected engine due to the cleaning effect of gasoline passing over the intake valves. When the same engine designs are adapted to direct-injection fueling, however, that cleaning effect is suddenly lost – and the carbon layers can build.
There is no simple fix for engines that are prone to carbon build-up, Chick says. What's needed is a complete redesign of the crankcase ventilation and exhaust-gas recirculation systems to prevent particulates from getting through. Fortunately, the manufacturers whose engines are frequently cited in carbon build-up reports – mainly VW, Audi and Lexus – appear to have taken this step with many of their latest models. For instance, Audi's new 3-liter supercharged V6, used in the S4 and A6 models, has so far been free from carbon-related complaints – a far cry from the 3.2 liter V6, which has numerous threads dedicated to the condition.
If Ford and GM engineers and Chick are correct, the carbon-buildup problem now may be relegated to previous engine designs that were not well-adapted for DI. But that's probably little consolation to some early adopters like Boyadjiev, who must add regular carbon cleaning services to their cars' ongoing maintenance requirements – a cost that, for now at least, they are expected to absorb entirely on their own as they grapple with the "dirty" secret of this emerging technology.
Mark Holthoff manages customer support for Edmunds.com.
Matt Landish oversees digital media development and publishing for Edmunds.com.
AutoObserver Staff: Mark Holthoff and Matt Landish
Or, if you want some insurance of cleanliness, get a service such as B&G's "plaque remover" to get those engine arteries cleaned out!
We all want our cars & bodies to be maintenance free forever and ever, but until we get pixie dust that actually works ...
ShoBoat
#69
Ok so I spoke to Andy at LMS, and here is his take on the great catch can debate. Now keep in mind that this is his opinion, which in my book carries a lot of weight for me. He has seen lots of examples where catch cans have compounded the issue. One car in specific on the dyno where the can caused some kind of vacuum effect and literally drained a quart of oil on a single pull. It was disconnected an they tried again and the oil level stayed constant. Second he believes that the DI engines need a bit of this lubrication that comes from the PVC valve. With port injection it came from the fuel, with a DI it comes from the small amount of oil vapour. This applies to the intake valves, some of the pictures that have been circulated around the net are extreme cases of this "cake" effect. Most likely due to poor maintenance (like lack of proper oil changes, cheap oil, air filter maintenance ect). He also mentioned something to the effect that the cans can in some cases interfere with normal flow of PVC gases (restriction) Which in his experience caused more trouble than they helped. It was his opinion that he would not run catch cans on his EB's, Maintenance is key. Although some of these products have their merits he would not use one. Only on extreme cases (1200hp crazy motors) He does not recommend them. If you are getting that much blow by then there is a mechanical issue with your car. He also made one last comment that kinda stuck with me. LMS could produce in-house a catch can and sell it, they have the capability. Because he sees no advantage to having it on my car for example he wouldn't want to recommend installing it. Hence why LMS does not make their own.  I trust LMS and they would not steer me wrong, a lot of what he had to say made sense.
I also askedd him about the issue with the clean side (where it exhausts under boost) about putting a can there (or a clean side separator). He had no objection to that, however he still wouldn't if it was his car only because he was unconvinced of the benefit to cost. If it makes you sleep better at night go for it.
This was my interoperation  of our conversation, I asked if they would post their official thoughts on the whole catch can debate and they will.
I will be monitoring my personal car, and I maintain my car religiously I am not too worried about it. I just know there are more than one SHO or F150 out there that is not getting maintained properly lol. Who knows.
I personally will do something on the "clean side" Just because. But as everything else in life this is just one of many opinions.
Edit, just one last thing before I forget. He had no specific opinion on the RX Catchcans, just catch cans in general.
Well articulated. :clap2:
dalum
The car that sucked out a quart of oil sounds like the can wasn't hooked up properly to me.  I have my Rx catch can and cleanside separator sitting here waiting for me to install it but now I'm not sure what to do.  I was already a little concerned with the stepping down of hose size from stock to Rx's lines restricting flow.  I also noticed the check valves had a lot of restriction when I blew through them as well.  I was hoping the guy with the first install had a cup of s*** after 500 miles but he didn't have anything at all?
On the other hand everything that TunerBoost has posted makes complete sense to me.
So we have...
Catch cans suck reserve oil out of the engine where its supposed to be.
Fluke? Bad install???
Oil in the intake air may help lubricate the intake valve.
Ok, but we see what oil accumulating and baking onto a hot intake valve looks like.
Check valves and smaller diameter hoses causing restrictions?
All the positives Tunerboost mentions?
Is there a reason why the factory line at the throttle body isn't capped, the check valves are deleted, and vacuum at the intake preturbo isn't used 100% of the time?
2013 Non-PP SHO
ShoBoat
I believe that the intake piping just before the turbo isn't used all the time is you really don't want the vapour running through your turbos and the intercooler. I personally believe that the weak link is that on the EB during boost the clean side becomes the exhaust, thus tossing the oil down into the turbos. I personally will be installing a catch can or something on this side. Also mentioned in my talk with Andy during dyno pulls there was no detectable difference with or without a catch can. This would indicate that there is not enough vapour entering the system to cause a reduction in octane to cause the car to pull timing ect.
Just my 2 cents.
I personaly have the RX crankcase evac with clean side physically installed in  my SHO but the lines are not not hooked up yet ... most of you know why .
At this time I'm tending to believe that Livernois does not  understand  the specialized qualities of the RX system and are basing there opinions on Generic catch cans that some people have used on other vehicles that have caused problem's .
Livernois's services  in general are exemplary however just because they say or have an OPINION on a subject matter does not make it a FACT .
There have been other issues that  Livernois is in disagreement with others such as E85 blending and t-stats where the members here have been left to decided the path they want to choose .
I for one want want HARD COLD FACTS and not opinions .
I will hold up on finalizing my install until Livernios updates the members here on this Major concern .
If this is based on there opinions and not factual based information from automotive indusry experts  , I will finsh my install as I tend to see a need for this based upon what Tracy says and the information that BG says on this issue as well as the tech articles that ShoBoat posted .
IF Livernois's info that we are waiting on Is HARD COLD FACTUALY based I will not use the RX .
Then the question is what can we get for these on ebay ?
SRT82ECOBOOST
Livernois Motorsports (LM) most likely sells more Ecoboost performance parts than any other company. LM would stand to probably make a tidy little profit from pushing a catch can into the hands of Ecoboost owners, even if it was just rebadging the product from another manufacturer. So if they are willing to pass on the opportunity for an easy sell, to me it further justifies their preliminary response as stated above to be their actual belief on the requirement of a catch can regardless of it being deemed right or wrong.
From the other side of things with the stance of RX calling for the use of the catch can, they have substantial benefits to be had by pushing a product for sales/profits. So if there is one side of the argument that would be more likely to be biased, one would lean towards the folks at RX.
