Torque Pro Missing PID's for Transmission Temp Guage .... and others
Started by SwampRat, February 21, 2014, 12:24:15 PM
ecoboostsho
So I finally got a chance to check the new Torque formula and it seem to match Forscan +/- a couple of degrees.  I tested it at 150 and 200 and it was very close both times so this new formula seems more accurate.  I honestly didn't test it at startup which was a miss on my part because I would like to know if it is off down low or not.  The good news is that this one seems to be accurate where it matters...at the upper end of the range...at least compared with Forscan.  The only way to really know I guess would be to compare it to an actual gauge and temp sensor.  I am going to update the original post as well to hopefully avoid confusion.
I'll change to the new equation later today and post some results.
Larrylu
Recently took a 4 hour each way trip and the tranny temp crept up till it stabilized around the low 170 degrees and remained there about 10 degrees cooler than my coolant temp (low 180 degrees)
ecoboostsho
Went and tested the PID with Torque and Forscan after letting the car sit overnight...
Ambient 75 Deg. F
Torque with latest formula: 79 Deg. F
Forscan: 79 Deg. F
I think we have a winner!
Larry - what speeds were you running and what was the ambient temp at the time.  Mine will consistently hit the 200-210 mark on the highway at 75-80mph with a ambient temp of 85 deg...
Larrylu
Ambient was mostly 50's & 60's and speed was mostly low 70's. With a 170 stat coolant mostly low 180 degrees. We haven't hit our hot weather temps yet.
