http://www.newegg.com/Product/Product.aspx?Item=9SIA32119W4037
Features :
1.Plug and play. HUD can auto adapt to vehicle type which in line with OBDII or EUOBD(On-Board Diagnostic System).
2.Comprehensive display. HUD can display many parameters at the same time as follows, vehicle speed, engine speed, water temperature (voltage, throttle valve position, ignition advance angle, time of 100 km acceleration), fuel consumption, mileage, low fuel tips, engine failure.
3.Diversiform display mode. Driver can chose normal display mode, high- speed display mode and automatic display mode.
4.Free switch. Km and mile can be switched freely to meet the need of inch auto meter.
5.Suitable size. The display area is 5.5 inches which is very clear for driver to read data.
6.Automatic power on and off. Starting with the vehicle starting, stopping with the vehicle stopping to protect the vehicle's battery. Moreover,
we pre- serve the hand switch function to control the HUD.
7.Flexible alarm mode. HUD can offer single-stage and four-stage overspeed alarm modes to choose to make driving safer.
8.Engine speed alarm. It contributes to shift gear in time to save fuel also has significance to new driver.
9.Flexible brightness adjustment. The brightness can be adjusted automatically or manually to reach the best state which is in harmony
with the environment.
Technical Indicators:
1. Service conditions:
Environment temperature: -400Cā+800C
Barometric press: 86ā106 kPa
Relative humidity: 10%ā95%
Environment voice: <=60 dB(A)
2. Alarm of sound level:> =30dB(A)
3. Work voltage: 9V~16Vdc(12Vdc/400mA)
4. Size of product: 14x85x147 (mm)
5. Weight of product: 350g
6. All of the electronic components are conform to ROSH standards.
7. Conforming to the China Compulsory Certification.
Installation Instruction:
1.To know your vehicle type and brand. Choosing the vehicle type which in line with OBDII standard, you can open the engine hood and find
a sticker under it. If the sticker has the letter"OBDII CERTIFIED",it means you can install the HUD.(Fig.1)
2.To check the vehicle diagnostic socket under steering wheel, you can find vehicle's 16pins socket.
And then connecting it with OBDII line. (Fig 2)
3.To put non-slip mat in flat position in front of the vehicle, you can adjust the angle of the HUD host over it.
4.To paste the reflective film above the HUD host in order to receipt the HUD host's data.
(You can ask for the worker in authorized dealer to paste the reflective film)Some tips to paste:A: You can evenly spray water on the windshield glasses.
B: Please tear the protective layer of the film, and spray some water to both sides it, then paste it on the place you want.
C: Leveling out water under the film by smooth object until no water and bubble inside.
D: when water evaporates, you can clean water and dust around the film.
5.To test the power, you need to turn on the HUD host and you will see vehicle's recent voltage, and then enter into the state of researching vehicle's
computer version. After that the HUD is installed successfully.
Package Included:
1PC x HUD Host
1PC x OBDII Interface
1PC x Power switch
1PC x Reflective film
2PC x Mats
1PC x Steady
1PC x User Manual
1PC x Contact
(Note:The stand holder is not included )
