Aeroforce Gauges for your Ecoboost vehicle
Started by EcoPowerParts, February 19, 2014, 01:37:02 PM
CroR1
I just installed mine last night, and I like them. The reason I picked this setup over crash is because this setup looks more low profile to me.
Big thanks  to ddlopes for helping me out. The hardest part was trying to get the cable through the dash. Initially I used a coat hanger and I could not get it to come out on the driver side due to the wire being hard to bend. After talking to ddlopes, he said to use a wire and play with it until it appears, but I realized I needed to use a wire that was softer and easier to bend, and 5 min later, I had the obd cable through the dash(make a note, do not use a coat hanger wire). The wire came out above the gas pedal, and I didn't even need to remove the floor panel that covers the Mid consul. Taped one cable to the wire, and the Second cable about 5 nches lower for the first cable, and just pulled the wire. It's very tight when it Comes to space and I was Concerned that cables may get stuck if I placed all on the same spot, plus that area would not bend and flex as easy through the dash when being pulled up. Hope thIs helps Someone in thE future.
Sabtaj1
Sorry to open this up but I just got a gauge from a friend and it seems to work for certain perimeters but others just holds what ever number was previous and just doesn't read. Not sure what I have to do in settings. It's CNF401 v3.8 and on a 13 Eco Flex. Maybe I just didn't get it set up right but I'm just confused. Any help would be greatly appreciated or if I have the wrong gauge. Thanks
13 Eco flex.
Just FYI guys, I no longer sell these on my site.
Sorry,
Mike
Sabtaj1
#183
Quote from: EcoPowerParts on April 05, 2016, 09:54:50 PM
Sorry,
Mike
I saw that.  I know a couple others were looking.  I may have figured out my problem.  I am on platform 1 but according to what I found on the f150 forum platform 4 should be the one im supposed to be on.  I will have to give it a try when I step out to my car here in a bit.  ok, just checked, that's what my problem was.  everything reads perfectly now.
13 Eco flex.
66 Galaxie
Sabtaj1
Well....  I haven't found the pod that I want yet that's small. So as of right now I used a "L" bracket with clear gorilla double sided tape. To the back of the gauge and the same method attached to the bezel of the cluster. It will do for now. Red wasn't my first choice. Wanted green to match the snow controller but it was a deal.
13 Eco flex.
66 Galaxie
Looks pretty good and it doesn't block any of the gauge info.  Nice job.
